:person_facepalming:
Sometimes me too.
EDITED
Sometimes me too.
EDITED
language, watch the wording please, family forum and all that… such profanity is not allowed.
@DB Custom
My prefered Tool shop had a promotion. They sell HSS and HSSE 8% for the same price. HSSE is much harder (what i prefer usually) but this tiny cutters are brittle enough in HSS. If they break deep enough (in something like this Aluminium) it is over.
I only used the second and third cutter. The hole was a bit to wide for the first one. But i have taken enough material away. Now i have 4 nice threads :partying_face: . And the screws fit perfect!
Cleaned the holes with a syringe a 25ga needle and IPA. And because practise makes perfect i went for a new TIR backlight. 2x iceblue 2x pink. Grinded down the tube (to compensate for the bigger driver).
Added two 24AWG wire at the spring (noticeable bump in brightness and heat :smiling_imp: )
I played a bit with iso and WB on the pictures. I would say the last two ones are close to the real color. Not 100% but close. But it is more dimm in real. Now the backlight is more even. Especially with this Special TIR survace.
This is with the old Backlight. Not so smooth.
This is the new one. More uniform backlight.
And yesterday i did a little mod to my hadband. I removed the chinese plastic and wrapped the headband with super soft 1mm leather. Much more comfortable and much better if sweat is running down your forehead.
@scianiac
Your light is so absurd bright! :partying_face: :+1:
Yesterday I modded this >200 year old oak tree as part of Operation Saluting Branches I was one of only two climbers at the Dayton Ohio national cemetery (there were 3 bucket truck crews there working as well) but me, a recreational climber who does a few tree jobs a month as side work got there and got the biggest freaking tree! So awesome!
Half way done in this pic, finished before lunch and took on a whole area of trees needing dead wooded by the monument, inaccessible by machines after lunch.
Nice work CK! Must have been a real trip getting that selection!
I got my 21700 Sofirn C8 host today and built up an Anduril driver for it, installed 3 Samsung LH351D 80 CRI 5000K emitters on the MCPCB then sliced the domes off. Having some switch issues but it looks like it’s gonna do around 3200 lumens on an iJoy 21700 3750mAh cell and the beam is pretty nice, decent hot spot with a nice tint. Rainy tonight but I haven’t forgotten I own a camera (or two…)
There should not be any difference between HSS and HSS with cobalt below 300 degrees C.
As far as i know the HSSE cutters are harder because of the cobalt (longer use of tool because less wear or you can cut harder materials). But like the cobalt drills they are more brittle. And from using both cutters i would confirm this. But i could be wrong.
Convoy S6 triple build
3x Nichia 219C 4000K
Carclo Narrow spot
Kiriba-Ru Copper pill
Dr. Jones H17Fx
Samsung 30Q
Clever bypass TheOnlyDocc!
@TheOnlyDocc, how did you actually managed to do this? This looks close to impossible since the heat from the soldering iron would travel to the other wire, and melt the solder joint.
You are quite skilled.
Simply clamp the first solder joint with stats, make your second joint.
I got 10 Osram Oslon Black Flats today, put the first one in a modified Emisar 1DS with Anduril, replaced the 18ga wires already in the light with 22ga leads. I SHOULD have re-flowed a copper disc under the MCPCB first to raise it up some, but did not. So I’m slightly back on focus point. Still, hitting 4.62A for 890 lumens at ~300Kcd. Pretty cool little emitter!
Thanks! Regarding the soldering. Practice makes perfect! But seriously, there are more much more skilled people here on BLF. But it helps to have a powerfull iron and the right flux/solder combination!
Wanted to build something instead of using this spring (cutting away a part inside the tailcap and fitting a strip of copper with a regular spring soldert to it). But i lost most of my electrical tools during a water damage. So modding the original spring in some way was the next best option.
e1000 nice combination! Like the S6 and the tripple looks nice in it.
Finished my BLF GT yesterday.
Stock driver and Lexel XHP35HI (my LED had only 3 working Dies)
Wavien Collar
Fresnel Lens
GITD Tape in the Reflektor Housing.
Not yet checked the Lux. I will do my Report on TLF, and perhaps link it here.
Why Fresnel?
Same hss can be hardened to different values. Cobalt cant increase hardness, it helps to increase “temperature resistance hardness”. If you work with material that is hard and ductile (some ss alloys, nickel alloys, titanium), you need sharp edge cutter that works with high speed. Regular hss cutter will loose its sharp edge fast after overheat, while hss with cobalt cutter can be still sharp with same cutting speed. Saving good mechanical properties with bigger temperature is what I call “temperature resistance hardness” (dont know right meaning in english).
@kiriba-ru
Thanks! Learned something new :+1: ! But if it only increases “temperature resistance hardness” why they are using it in threadcutters? Or do they really get so hot in special occasions?
@Wieselflinkpro
Interested to see how it works out! I could bite my A… not buying the GT when i was able to buy from the first batch on the GB list.
Cobalt is usually added to raise the “hot” hardness. They are not harder, they just maintain hardness at a higher temp, less thermal fatigue over HSS. For an example would be in production tap heads, were cycle time is critical, so they push the limits to produce more parts at a higher rate.
Nice to know. So absolutly no gain for hand cutters! Maybe if i can increase my wrist speed a few %
But i am not wrong that it makes it much more brittle? The HSSE cutters i have are so delicate.
It is cheaper, less heavy and allows bezel-stand.
And its easy to fit. I have sanded it down.
There is althoug a glas lens wich will fit, but you need a printed adapter to hold it properly. Perhaps I will change it later.
First I wanted to try if it works.
The main advantage of the GT for a aspheric mod is, that the reflector-housing can be screwed from the LED-Engine. First you have enough room to set the focus to the Wavien Collar and later you can adjust the focus of the lens.
Yes of cause. I got it for the cheapest price.
Selling this one would have been easy, if you dont like it after buying. If you buy it now, you will loose money in contrast to the first prices.
Put a 4000k (xm-l2) emitter in a new V11R that I found cheap. Very nice tint and finally I have a rotary light.
Didn’t expect it, but it was one off the easiest mods. Light opened up pretty easy with some rubber and a vice.
Now to find a way to machine the tube to 18350.
