Looking to order a couple drivers for my H03 please. With temp and lvp precalibrated. And I guess the short springs? Whichever spring is most commonly ordered with this driver, it’s my first time.
Hi Lexel,
I’m not sure if this was long ago asked, do you have a 21mm driver planned for use in the Sofirn C8F 21700 version? So e-switch, Narsil (Anduril?), FET+7135, no components at battery side because of thick retaining ring. A nasty feature of this host is that the rim on which the driver rests is rather wide, more than a mm (I can measure the exact width if needed), so the components should not be much further to the side than a 17mm driver.
If you can make this, I’m interested!
Same thing as djozz too.
The C8F 21700 looks dope, and I would love a driver with it in a triple NarsilM linear+FET arrangement, or even a boost driver if possible.
Lexel does not do Anduril and has no interest in it. Sorry.
I ordered a 20mm e-switch driver from him for the 21700 C8F host. Not sure if it shipped yet or not but I guess we will see how it fits or what mods I need to make to get it to work when it arrives.
For C8F with 21700 I need excact measurements for the driver to make a new design, could be basically a modified 17mm one
I hope Sofirn does at least modified the head so the MCPCB gets screwed on the head, got always shorting issues with the original design as often the head cut in the wires or if not screwed on the reflector shorting to reflector
20mm might work, I can sand it bigger after cutting out from a 10x10cm board so its 21mm but copper only 20mm wide
not sure if the silkscreen of the 20mm will be a problem with the retaining ring
I have downloaded Anduril a while ago but never come to really use it as it was mostly a problem to get it work with Atmel Studio
Today I tried to download the BLF GT Anduril Hex but not found on server
I worked today on Ramping IOS and Anduril and got both working to compile a hex without errors in Atmel Studio
Goodness
:+1: Cool, thanks.
Question, Is there a boost driver with Narsil firmware? I just purchased a Lumintop ODL20C that uses a XHP-35 HI Led powered by a single 26650 cell and was wondering about modding potential for this little pocket rocket.
Thanks!
AlexGT
AFAIK he is still working on his boost drivers getting the software side of things to work properly.
Modding potential for the ODL20C is unknown. If it has the integrated side switch on the driver (like the ODF30), then you might be screwed. You’d need to design a driver from scratch or somehow rig up a side switch.
If it has a seperate switch, you are in a better position. Unfortunately, we are still waiting for boost drivers. MTN E has released his first boost driver, but it’s a small diameter and small powered. The ODL20C needs a bigger driver with more power. Richard also hasn’t got his e-switch firmware working on them.
It may be several more months before we see any proper e-switch boost drivers. Maybe 6 months, maybe more.
Ps, you’ll probably loose the built in charging.
Personally, I would not mod the ODL20C. I would start with a Utorch UT02 for about $25 because it’s cheap and I know it has a seperate switch. Then swap the driver once we have a good boost driver available.
Hi JasonWW, will it be possible to retain usb charging if one swaps the driver of the UT02?
It’s highly unlikely, unless your a really good modder and electrical engineer. On the plus side, the charging board in the UT02 looks seperate. You’d need to figure out how to attach it’s wires to your aftermarket driver.
In looking up driver pics I see the UT02 might be glued. Then again, the ODL20C might be glued. My ODF30 was glued between the battery tube and head. It was a beast to get loose.
You might check if your ODL20C is glued or not.
I see what you mean. It’s a pity because some of us actually want to retain the USB charging. I wish more manufacturers would integrate the USB charging into tnr battery tube like the Haikelite SC01/SC02. Thanks anyway JasonWW
Mind if I ask what parameters you used for Anduril?
I wonder, because I’ve decided that’s what I want to flash onto the H03 drivers you’ve sent me.
I’ve been doing some research, and the closest I can find is something in the main Anduril thread where someone said “The TA uses 3 power channels, so the #define for the FW3A might work.”
So I’m assuming that’s a good starting point? Does anyone know if this still holds true?
Sorry, I know Anduril isn’t your thing and you’re just getting started in it. I just love this UI so stinking much I flashed all my compatible lights over to it already.
FF ROT66 should be also compatible
you got to look in the setup files for the lights that contain the ramping table and mode sets
I need another 15mm driver with presoldered 2× 2-inch wires and a short spring. Plus a custom programming as follows. What would be the cost of this? Thank you!
1. TURBO should be set at 0.002*FET (yes ~10ma)
2. custom modes:
1: 2, one7135, all7135
2: 3, one7135, all7135
3: 5, one7135, all7135
4: 6, one7135, all7135
5: 7, one7135, all7135
6: 4,6, one7135, all7135
7: 4,7, one7135, all7135
8: 5,7, one7135, all7135
9-22: default
23: 1,2,3,4,5,6,7,8
24: 6,7,8,9,10,11,12,13
25: 11,12,13,14,15,16,17,18
26: 1,one7135,3,one7135,5,one7135,7,one7135
27: 6,all7135,10,all7135,14,all7135,18,all7135
Plus intl shipping
Thanks!
Ok thanks! The ramping table, as in the code that tells the driver exactly how to combine the fet and 7135 to get the correct current for each step in the ramp? I assume that changes depending on hardware config?
Sorry, this is the wrong place for this. BLF is hard to navigate through all the information.
2. custom modes:
8: 5,7, one7135, all71359-22: default
23: 1,2,3,4,5,6,7,8
27: 6,all7135,10,all7135,14,all7135,18,all7135Plus intl shipping
Thanks!
Lowest step is 1/255 for FET, AMCs usually 2-3
