Before I would gift them to muggles, I would check that is has low voltage protection. I don’t think the included battery is protected? So if it doesn’t have lvp, I’d swap in a protected 18650.
Good point. I hope it has LVP.
5350-5700K
2200mAh battery included
No separate charger. I just telling it has the same function of light+battery+charger for that low price.
Who are muggles?
No LVP, but the indicator does remind of low voltage. If the voltage down to 2.5V, light turns off, just recharge it with the USB charging cable, it comes back to life.
Who are muggles?
In the world of Harry Potter, muggles are non-magical people.
On BLF, muggles are people that don't know much about flashlights or Li-Ion cells.
Love your lights! You should consider starting to use slightly lower temperature LED’s though (4000k-5000k)
I use to feel that way about Sofirn lights but now I don’t care even if they use 8000k blue-white emitters because the majority of Sofirn lights are not glued and very easy to swap out the mcpcb for other emitters. Just buy some 16mm mcpcb with 4000k or 4500k E21A from Virence.com or a bunch of other emitter options from Kaidomain and MTN and swap it in. Sofirn lights are very mod friendly.
5350-5700K
Personally, I think this is a great choice. CCT offerings such as this is one thing that has attracted me to Sofirn from the very beginning.
Besides the fact they make a great light of course.
Keep up the good work Sofirn!! :+1:
The SC31 looks good. I am in for 1. Found a 20% coupon.
I love the Sofirn C8F 21700. Truly advanced technology at an affordable price.
Wait, I didn’t know the C8F 21700 also included levitation technology.
Looks like it’s floating at the table.
LOL :+1:
EMALS
JWST
C8F 2170
2 much good stuff!
Lightning Deal of Sofirn Q8 ended. How many of you get it?
C8F is still waiting for you to order. I know some of them, 30% of the inventory, don’t reach the max 3500LM, and that’s why the price is low. We promise a new driver for you to
replace.
In the C8F 21700, it is really hard to see a difference in brightness between the old driver and the new one, so even the old driver is not what I would call “bad”.
Sofirn, it might be best to rate the C8F 21700 lights closer to 3,000-3,200 lumen instead of 3,500. This is more realistic and people will not be disappointed if it’s less than 3500.
Please take a similar action on the C8F 21700 on Aliexpress. Shipping from Amazon is so expensive that the purchase is not worth it.
Thanks for the suggestion. Our way is test the max output for every C8F (21700) light by integrating sphere. I believe the second batch will be okay.
We want to clear the inventory of 1st batch. The price after code for C8F 21700 kit is only $32, isn’t it good enough? I know, about 30% of them won’t reach 3500 LM but we promise a
new driver for you to replace.
please pm for code.
Thank you for the Amazon C8F bundle code. Order placed.
ONLY $32 for C8F 21700 Bundle with 4000mAh 21700 battery inserted and coming USB charging slot.
Are you going to be adding built in charging to the C8F?
And then, of course, I’ll have to buy 1-2 of those, too… :person_facepalming:
