Convoy S6 triple build
3x Nichia 219C 4000K
Carclo Narrow spot
Kiriba-Ru Copper pill
Dr. Jones H17Fx
Samsung 30Q
Clever bypass TheOnlyDocc!
@TheOnlyDocc, how did you actually managed to do this? This looks close to impossible since the heat from the soldering iron would travel to the other wire, and melt the solder joint.
You are quite skilled.
Simply clamp the first solder joint with stats, make your second joint.
I got 10 Osram Oslon Black Flats today, put the first one in a modified Emisar 1DS with Anduril, replaced the 18ga wires already in the light with 22ga leads. I SHOULD have re-flowed a copper disc under the MCPCB first to raise it up some, but did not. So I’m slightly back on focus point. Still, hitting 4.62A for 890 lumens at ~300Kcd. Pretty cool little emitter!
Thanks! Regarding the soldering. Practice makes perfect! But seriously, there are more much more skilled people here on BLF. But it helps to have a powerfull iron and the right flux/solder combination!
Wanted to build something instead of using this spring (cutting away a part inside the tailcap and fitting a strip of copper with a regular spring soldert to it). But i lost most of my electrical tools during a water damage. So modding the original spring in some way was the next best option.
e1000 nice combination! Like the S6 and the tripple looks nice in it.
Finished my BLF GT yesterday.
Stock driver and Lexel XHP35HI (my LED had only 3 working Dies)
Wavien Collar
Fresnel Lens
GITD Tape in the Reflektor Housing.
Not yet checked the Lux. I will do my Report on TLF, and perhaps link it here.
Why Fresnel?
Same hss can be hardened to different values. Cobalt cant increase hardness, it helps to increase “temperature resistance hardness”. If you work with material that is hard and ductile (some ss alloys, nickel alloys, titanium), you need sharp edge cutter that works with high speed. Regular hss cutter will loose its sharp edge fast after overheat, while hss with cobalt cutter can be still sharp with same cutting speed. Saving good mechanical properties with bigger temperature is what I call “temperature resistance hardness” (dont know right meaning in english).
@kiriba-ru
Thanks! Learned something new :+1: ! But if it only increases “temperature resistance hardness” why they are using it in threadcutters? Or do they really get so hot in special occasions?
@Wieselflinkpro
Interested to see how it works out! I could bite my A… not buying the GT when i was able to buy from the first batch on the GB list.
Cobalt is usually added to raise the “hot” hardness. They are not harder, they just maintain hardness at a higher temp, less thermal fatigue over HSS. For an example would be in production tap heads, were cycle time is critical, so they push the limits to produce more parts at a higher rate.
Nice to know. So absolutly no gain for hand cutters! Maybe if i can increase my wrist speed a few %
But i am not wrong that it makes it much more brittle? The HSSE cutters i have are so delicate.
It is cheaper, less heavy and allows bezel-stand.
And its easy to fit. I have sanded it down.
There is althoug a glas lens wich will fit, but you need a printed adapter to hold it properly. Perhaps I will change it later.
First I wanted to try if it works.
The main advantage of the GT for a aspheric mod is, that the reflector-housing can be screwed from the LED-Engine. First you have enough room to set the focus to the Wavien Collar and later you can adjust the focus of the lens.
Yes of cause. I got it for the cheapest price.
Selling this one would have been easy, if you dont like it after buying. If you buy it now, you will loose money in contrast to the first prices.
Put a 4000k (xm-l2) emitter in a new V11R that I found cheap. Very nice tint and finally I have a rotary light.
Didn’t expect it, but it was one off the easiest mods. Light opened up pretty easy with some rubber and a vice.
Now to find a way to machine the tube to 18350.
Cool mod. Do you have a description of what diodes (1203 etc.) you used and where did you connect them in the flashlight?
I used 0603 leds from ebay This two colors are the only ones in my collection that could run together without using resistors to balance the output. But if you ask our electronic gurus there are maybe other leds that can work together without balance resistor (or i find a way to add resistors to the mix). I used a Lexel Driver with NarsilM. So backlightled+ connects to the switchled output (so if using battery check . . . the backlight is blinking ) and backlightled - connects to the switch groundpad (i disconnected the original switchled because i did not want to have another color on the side and because the silicone cover is precolored i could not get the color right even with changing the original led). The wires from the switch still going down on the right and the backlight wires going down on the left side of the head. So you have enough space for the wires arround the TIR to not show through the TIR.
A foil pcb (do not know the exact english name) would be great. Even smaller and with optional resistors (and if the design is right it could be a strip that you can cut into the right length. Wrap it arround your TIR Tripples. . . Cut it solder wires to it and ready. Could be something somebody can make a few bucks with (if its possible to get custom foilpcbs cheap.
The price of Flex PCBs is clearly the problem here.
The cheapest options I could find were around $100 for low volume runs. So that’s not going to happen. From what I found on forums like EEVBlog you would need to order at least 1000pcs to get acceptable prices.
Since you’ve tried it with a flex PCB, do you think a thin (0.8mm) PCB in the style of the D4S could also do the job?
It all depends on the space behind the TIR. I have not the exact measurements from the H03 (i made a paper template to cut it to size). But there is not much space if you put the leds near the top of the TIR (best effect).
If you make it small and put it ~beside the DTP board it should fit. But you see the leds directly through the TIR. So the effect is not as good. To bad we are not living in shenzhen. I saw a video on youtube with a guy building a 3,5mm hadphone jack into an new iphone. He needed also a flex pcb and went to the market (a few contacts later) he was giving them the (gerber?) files and another few days later he was getting the flex pcbs (and it was cheap!! :cry: )
Maybe i find something that workes better and is cheap. But for now i tried 0,1mm and 0,2mm copper wires (soldering everything together is a absolut pain), to use flat (like flex pcb) wires out of a car (the flat wire that is wrapped arround your steering collum and connects to the airbag in your steering wheel), to using this tiffany copperfoil on Kapton tape. So it is not the first try. And maybe someone here on BLF has a Brainfart and comes up with something that makes it work cheaper/better. … . or i see something that trippes the switch in my brain.
Duty scratches always look so good on lights of others. When I scratch my own I somehow never see it that way.
You could always send him one of yours to scratch up, then send back to you, no?
