Water Cooled Flashlight Modding a MT35 PLUS aka MF04 ( COMPLETED )
66 posts / 0 new
CNCman
CNCman's picture
Last seen: 5 hours 37 min ago
I am going to do a mod that will take a few weeks to finish the first of 3 mods to the same light. Is the featured mods the correct place to start this thread ? Thanks Beer
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
Edited by: CNCman on 12/29/2019 - 18:43
CNCman
CNCman's picture
I am a newbie here to Lithium powered flashlights and BLF. So you will see many missteps and screw ups and please let me know so the error will not be repeated. When I first found BLF, I was so happy to see all you good people helping each other, I wanted to join and try to contribute something. So after buying a MT35 PLUS and using it, well it would shine far but not bright. Looking to mod it we found this http://budgetlightforum.com/node/57036 and the idea was born in this thread. This will be a 3 part build. Part 1 will be to design and build a water cooling system with pump using a 12v 7amp driver from Lexel to power the pump and XHP70.2 led. If the cooling is successful then proceed to Part 2 which is an upgrade to a CTF-90 and 40 amp driver. And finally part 3 which will be adding the Aspheric lens http://www.optolife.com/singlet_lens/A380.html. The reason for not going to the CFT-90 first is we didn’t think it could be cooled, even with water. So here are a few pics of the progress so far.
Planning and design, using Solid Edge 2D Drafting FREE CAD software https://www.plm.automation.siemens.com/plmapp/education/solid-edge/en_us... for all drawings.
Programs used to make the upper copper cooler half only.
This will hold a copper 17mm mcpcb with the XHP70.2 12v led.
The MT35 head will get a hole bored in it to accommodate the copper cooler.
EasyB
Last seen: 1 hour 39 min ago
Interesting project. The copper heat exchanger looks really cool. How do you plan to move the heat from the water to the air?
Why do you want to use an aspheric lens? It will increase throw by a bit? Light collection efficiency of a lens like this is only 25-30%. Whereas a reflector puts 70+% of the light into the beam. If you really want to use a lens I might consider using a precollimator lens which can double the light collection efficiency.
LichtAn
Last seen: 10 months 18 hours ago
Holy smokes, this will be interesting.
thijsco19
Last seen: 6 hours 6 min ago
Looks great!!
LichtAn
How will the pump be mounted and where?
CRX
CRX's picture
Last seen: 24 min 44 sec ago
Cool project Thumbs Up
CNCman
CNCman's picture
The pump will be externally mounted somewhere, I have not tackled that one yet, but somewhere opposite the button switch.
Enderman
Enderman's picture
Last seen: 1 day 8 hours ago
Nice project! What rads do you plan to use for cooling?
CNCman
CNCman's picture
The heat will be displaced from an aluminum coil mounted around the head, but no fan for that.
I wanted to have it zoom-able for flooding and throw, not sure how effective it will perform for either one until its finished.
CNCman
CNCman's picture
1/4 in diameter soft aluminum tubing wound around the head 2 times with .100 in gap between coils. No fan.
I have been trying to learn from your builds so we all kinda work together and share. Beer
The coil is in work to get finished this weekend if everything goes as planned.
Using the head for the mold.
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 10 months 3 weeks ago
How much heat (W) do you want to dissipate with the coil? Build a few watercooler for CPUs and Motherboards myself a few years back. And also build a lot of custom cooling solutions. Interested to see how you fit it together.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
Enderman
Enderman's picture
![img]https://i.imgur.com/WrxrbNJl.jpg[/img]!
Nice.
Is that like 25ft of coil?
Should definitely be enough for a CFT90 as long as you don’t do more than 30-40A
CNCman
CNCman's picture
“TheOnlyDocc” Sorry, I’m not able to know the amount of heat except from reading and guessing how much trouble
everyone is having with thermal step down after a few minutes run time. I’m not sure this idea will work at all, but I could not
resist the opportunity to try and maybe throw some information into the hat for everyone to use.
“Enderman” Yes it is a 25ft roll. Trying to squeeze as much as possible on it and not take away too much flashlight appearance. I have yet to solder the spacers in place and form it into shape. I will give the total feet used for reference so the guys who know how can do those if we can give them accurate info. Beer
CNCman
CNCman's picture
Aluminum soldering proved too difficult so small stainless steel wire was used to assemble cooling coil.
Ready for heating with Kester EP256 Lead Solder Paste 63/37.
Battery tube in work now.
More pics next week. Still a lot to mod before completion.
AlexGT
AlexGT's picture
Last seen: 1 day 2 hours ago
Interesting, Keep up the good work!
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 49 min ago
Epic build Smile Will be following this Cool
TheOnlyDocc
I noticed that you are using copper and Aluminium in the same loop. This will get you corrosion fast. Had the same problem in a PC watercooling loop. Even with very high quality additives. It takes longer but eventually it happens. And the solderjoint that have contact with the water will also be a week point.
CNCman
CNCman's picture
Yep , that’s a good point. I had read some on this subject, mostly for best heat transfer. Corrosion was mentioned often as a concern and freeze preventative which can lower cooling efficiency. Probably will use automotive coolant and empty the system while in storage and flush it clean, but not sure what corrosion preventive to use at flush and leave dry.
:ARROW-RIGHT: This is all a guess for me, so if anyone has a suggestion please feel free to say something, I’m just a newbie here, I can machine things but I know little about flashlights.
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 51 min ago
So, has the project been finished or not?
I’d like to know Smile
moderator007
moderator007's picture
Last seen: 6 hours 1 min ago
Looking Awesome CNCman. Can’t wait to see the finished build.
Have you got any updates on this project.
Very good pics by the way. Thumbs Up
hank
hank's picture
Last seen: 4 min 27 sec ago
Will it have a steam whistle for overpressure release?
electricjelly
electricjelly's picture
Last seen: 2 days 15 hours ago
I just ran across this. Very ambitious build. Some good ideas I see here. I’m curious to see how it will work. I’m wondering if convection would be enough to move heat without a pump. Probably not,but it probably doesn’t need a lot of flow to be effective.
CNCman
CNCman's picture
Sorry guys for not responding. We have had a few Life Events and are just recovering from it all. I will now begin finishing the light and post pics on the progress in a few days. Facepalm
mattadores
mattadores's picture
Last seen: 4 months 4 weeks ago
Hey, this looks like an amazing project! Very excited to see how it progresses!
ZozzV6
ZozzV6's picture
Last seen: 2 weeks 5 days ago
Great build!
I am really curious about end result. I think you could have been bought a 6V bigger MCPCB and mod it to 12V. Not a big deal. Just two cuts with a dremel and a thick wire.
CNCman
CNCman's picture
Sorry about the loss of pictures here, I will attempt to replace them.
Also, I have finished the parts that were missing and plan to start finishing the light the day after Xmas.
This build became more than I was able to handle and was delayed for lack of experience.
Of course the intent has never changed and that was to eventually put a CBT90, SBT90,
or some hot led in it, keep it cool, and determine how much water cooling is required.
Afterwards a new design can be incorporated that will have a normal appearance.
This light is for testing, not looks, so I will not be offended by comments.
Yokiamy
Yokiamy's picture
Last seen: 3 hours 14 min ago
Do you have more info about the cooling of the LED/shelf?
If you can reduce the heat of the shelf drastically you dont need all that aluminium wound up next to the head, if you could just take out the heat below the LED.
Or is that your heat exchanger?
CNCman
CNCman's picture
The MCPCB is .062 thick and will be inset into the copper cooler. The copper cooler is .100 thick it will sit on.
Im guessing this is the shelf you are asking about. As far as technical info on cooling capacity, no I am no Engineer. Sorry.
Yes , you are correct, in after thought and already in deep, it is overkill.
The aluminum coil is the radiator and the copper cooler is the heat exchanger.
They will be connected and water will be pumped / circulated thru both.
CNCman
CNCman's picture
Here is the battery holder extension to 12v and 8 batteries.
Had to use .250 dia aluminum roundstock and turn it down to .190.
Heat shrink tubing was used on the factory rods, so we did too.
djmcconn
djmcconn's picture
Last seen: 13 hours 48 min ago
Absolutely love this build. Fantastic so far and thank You for sharing!
