OTOH, perfect CRI does not always give the most vivid colors. Sometimes wide-spectrum can make colors pop more than high CRI. Getting the mixture right can be tricky though… and if done wrong, it looks bad.
I haven’t done a 3000K + 5000K mix yet in a flashlight, so I don’t know how it looks. It’ll be interesting to find out. Two 3000K and two 5000K bulbs works really well for bathroom lighting though, and makes it much easier to discern subtle shades while applying makeup.
Ditto this. My EDC for the past ~1.5 years has been a mixed tint XP-G3 based triple. It uses a 90cri 5700k, 90cri 3000k and a 5000k with a forgotten CRI.
I keep trying other LED’s and setups but just can not get anything that can match the tint and color in the real world to the human eye.
The only other LED that comes close is the 9080 219B but it gives up too much output but it does look a little better.
Tint mixing 2700K with 5000K, as I think is planned for the lantern, does not get you as far below the BBL as the 2700K/6500K example in the graph from Yuji and the Zanflare T1, and the CRI will therefore not be that far off either.
I would have loved to test an array of 3000k and 5000k Samsung LEDs, but I haven’t actually ordered LH351Ds 2700-3000k to see how the tint mix would work at full power.
The problem is that I only have 3000k LH351Bs and 4000k LH351Ds, and mixing them together would not be too smart since their forward voltage is different.
Also, I’d like to add that we need a quality manufacturer for the USB cable. 20-22AWG power is necessary at 12FT/4M. At that length, we need as little Vdrop as possible.
That’s really strange. I haven’t had any cable rust at all.
Then again, I’ve only ever bought high quality USB cables.
Speaking about this, I think we should perhaps have UGreen do the job with the USB cables. They’re an OEM which make excellent inexpensive high quality cables.
So is 2700K set in stone now? I know it was between 3000K and 2700K. I love the idea of 2700K, but it is a huge drop in efficiency (almost double the losses from 5000K to 3000K) for a small change in temp.
not set in stone, but everyone seems to want the 2700K as the warm-end of the tint ramp. I only had the chance to test the 351B series of 3000K and 351D of 4000K, ( i have nto been able to get any 5000K to test or 2700K to test.
