What is the price on the 21700 C8F? Are they still for sale?
This would be my first 21700 light and have always thought that the 21700 would fit the C8 better anyways.
I think you can get it for around the same price at Amazon with their coupon.
Also, know TA he may want to order 2x hosts for the same price from their aliexpress shop
Looks like my reputation proceeds me lol.
Finally have my 21700 C8 host working with the rubber boot installed. I had made a shim to be sure the boot wasn’t holding the button down, didn’t work. So today I used my Proxxon rotary and carefully reduced the length of the brass post coming up out of the switch. Put the boot in (shim still in place) no worky. VERY obvious space between the post and boot, but no good. Without the boot it works fine. So, I looked around on my table and found the black plastic tray some FET’s came in. What they call the “tape”. I cut the bottom out of one of the containers and placed this inside the boot, removed the shim, put the light together… and it works! The rubber is soft enough that the switch depression rebounds and Anduril doesn’t recognize the press. So now with this thin bit of plastic in there it gives a positive enough click that Anduril sees it and the light works fine. Go figure…
This only happens with Anduril?
So far as I know, Anduril seems to have a higher sensitivity to the button press timing…
I think 6-emitters would be the grail C8. I think LED4Power is coming out with a kit for the Sofirn 21700 C8F. Hopefully Kiriba-ru will make a copper spacer for this as good heat sinking is critical if we want to max the output.
Eh, your talking about TIR optics, though. There’s already a lot of lights out there that use multiple TIR lenses. The really nice thing about the C8F is that it uses a reflector. Now if we could get a 4 or 5 emitter version with a reflector, now that would be really cool.
Someone made a 7x reflector C8. But the head is huge. Don’t think we can fit more than 3 reflectors in a practical C8 form factor. Why is TIR bad? I think you only lose 5-7 % output compared with reflector.
I MUCH prefer TIR optics over reflectors as a rule. You might loose a few OTF lumens but you gain a much more usable beam.
I did countless tests between TIR and reflectors a few years ago and almost every time I decided I preferred the TIR.
In today’s world of LED’s with rampant tint shift issues, the TIR is even more important for me. A beaded surface TIR can eliminate almost all tint shift with minimal effect on OTF lumens or even the beam shape.
That 6x C8F looks quite interesting, I would be down for 1 of those.
Skylumen Vinh said he loves TIR too. I’m guessing the real drawback is you can’t make a TIR light throw as well as with reflectors.
I don’t like the lack of spill they give. All the light seems to go straight ahead and when walking at night you can’t see your feet and where to step or things to your left and right. I have the DQG tiny 7x and I have to wave it around to see. A reflector based light I can hold steady in front of me.
I’ve heard there are certain TIR lenses that give a reflector like amount of spill, but I haven’t tried those or know what model they are.
If someone wanted 6 emitters, there’s no need to convert the C8F, just buy a Emisar D4S, DQG Tiny 7x, etc… There are plenty on the market already so converting makes no sense to me.
In that testing I mentioned earlier, I generally got about the same or better throw from a good TIR as an equal sized reflector. The difference is that the TIR had about 2x the hot spot size.
In that extensive testing I did, I found that a lot of TIR optics that were not aimed at pure throw give about the same amount of spill in the real world out to most of your vision range. Particularly the frosted or beaded tir optics.
The difference was at the very edge of the spill, the reflector would have a sharp cutoff and it would be brighter at the edge where the TIR would fade out, making it appear not as bright.
If you use a frosted tir optic on the other hand it can easily have more spill then a reflector, which is another nice thing about TIR optics, you can pick the beam that is right for you.
For example I prefer the 10511 triple optic over the more common 10507, it is a bit more floody but gets rid of tint shift and I find the beam more pleasing.
If you have a triple 20mm light, I would recommend getting all the various optics for it from the floody to the frosted models and trying them out.
I’ve built many a light, with all kinds of set-ups… and I much prefer a reflector as compared to an optic. Of course I have plenty of optic triples and quads, but I also have triple and quad reflector lights. I have more than a few single TIR lights as well and it goes without saying that a majority of my lights are single reflectors. Hands down, I prefer a reflector. The pebble faced optics like an Ledil CUTE-3, I sand smooth and polish clear. I do like the look of the honeycomb, but I like to see inside much more. On the short side of a thousand builds, I prefer a good well made reflector and a high quality dual side AR coating.
Would buy immediately! For example 6 * XPL-HI TIR 4000-5000K. I like C8 much more than D4S
Upgraded with NOCTIGON 4XP 33MM MCPCB & NICHIA NVSW219CT R9050 D260 and Ledil Angie-S Quad LED optics
Pretty cute turned out : BLUSH:
Where is the heat given off? Under diodes hole?
Will there be a description on the forum.fonarevka?
