GEN 1, 2 are ready to build and sell
as usual custom color combinations possible, like rainbow up to 8 different colors
GEN 3 atm only with 6+1 colors,
17+20mm mm one channel no trimmers
on the 20mm with trimmers in 2 different groups
I have made one with 8+1 with cut out boards for easier production 20mm will be mouse bites
but this will take about 10-12 days to get the boards delivered
of course the further the development goes the more it will cost (parts, labor and development time)
Electrically should work with any driver that’s not effected by adding a 1kohm bleeder.
Should fit in 6P and 6P clones tailcaps, can’t install in malkoff MD or boss tailcaps as the switch is inserted from the top.
How about a gen 3.1 idea?
3 + 3 (or 4 + 4) LEDs would be placed alternately. 3 blue for “normal operating” light, 3 red for low voltage indication. The red LEDs would be blinking type like this.
So if the battery voltage is low then the signal will be conspicouos.
I just bought some 100K 3x3x2 to try out on some of my lighted switch mods. It should definitely beat having to constantly swap resistors to find that sweet spot between brightness and current consumption.
Edit, looks like you use 20K. I wasn’t sure if that would be enough.
Will the R7 - R12 resistor hit the shelf? I look at some common flashlight and the LED may hit the shelf for those. Can it be put somewhere like the back? I guess the back need to have space for the top of the switch though..
