I’ve built many a light, with all kinds of set-ups… and I much prefer a reflector as compared to an optic. Of course I have plenty of optic triples and quads, but I also have triple and quad reflector lights. I have more than a few single TIR lights as well and it goes without saying that a majority of my lights are single reflectors. Hands down, I prefer a reflector. The pebble faced optics like an Ledil CUTE-3, I sand smooth and polish clear. I do like the look of the honeycomb, but I like to see inside much more. On the short side of a thousand builds, I prefer a good well made reflector and a high quality dual side AR coating.
Would buy immediately! For example 6 * XPL-HI TIR 4000-5000K. I like C8 much more than D4S
Upgraded with NOCTIGON 4XP 33MM MCPCB & NICHIA NVSW219CT R9050 D260 and Ledil Angie-S Quad LED optics
Pretty cute turned out : BLUSH:
Where is the heat given off? Under diodes hole?
Will there be a description on the forum.fonarevka?
Nice mod John, I wish I could make adapters like that!
That is nice! Great looking finished product, way to make use of the new Noctigon board and it’s accompanying optic.
Wow… that is a really sweet mod there johnkey68 :+1: Been looking for a suitable host for the new Noctigon quad board/optic and my 30T cells I have laying around. Is the pill you made a press fit, it looks like you followed the profile of the inside of the host/head for a tight fit?
:heart_eyes: :+1:
Wow John, that is amazing! You might want to consider selling a kit . Maybe make the spacer out of copper too. I think the C8F is a better host for a quad than the D4S because it has more mass for heat dissipation.
A kit sounds good
Hey Sofirn C8F 21700 owners!
I am looking for floody single cell light with high capacity and good heat transfer.
I am not (so much) interested in maximum lumens, but I am interested in how much lumens C8F can pump out in continuous use without heat throttle and how many minutes its 4000mAh battery lasts in that mode.
Would 5000mAh 10A battery work with it in my use?
Do you know any similar lights around same price range that could be better for my use than the C8F?
Some other battery type flashlight maybe?
The Sofirn SP31A would be a good bet in the 18650 realm.
Since it uses a buck driver and an XPL2, it is a very efficient light, and still throws quite well, and can maintain its brightness for a long time. It also has a big heatsink, so you can hold the 1000 lumen turbo for quite a long time. It also uses a dual switch setup like the C8F 21700, which is very useful.
If you want something big and with a lot of runtime, I would recommend the SP33. 26650 light. You can get a 5500mAh 26650 for very long runtimes.
The C8F is a hotrod light mainly, so the lumens will go down if you use it above low brightness, and can get extremely hot.
Hey you! You did bring me here from reddit
How long of a time are we speaking of with “quite a long time” as second highest mode on SP31A is 350 lumens which seems bit low maybe, would it stay on that mode untill battery goes out? Ofc I do not know what is realisticly possible on this size flashlight. Anyway that is more than C8F’s low which is 100 lumen. 700 and 500 lumen modes will eventually throttle down to 100 lumen with C8F yes?
SP33 looks quite nice too, but will it stop thermal throttling on 500, 250 or 45 lumen mode?
350 lumens should easily last 3hrs of constant brightness since it only pushes a bit less than 0,95A to the emitter on the SP31A.
It won’t probably thermal throttle on the 500 lumen mode, and it will step down on the timer, but you will be able to get the 500 lumen mode back up.
Is this about SP33 or C8F? If both can manage constant 500 lumen, then added max lumens on C8F feel tempting, even though I’d need to pay quite alot more for it than SP33 (damn taxes on 22€+ shipments)
The SP33. The C8F can’t actually manage more than 100 lumens of constant brightness, so the 500 lumen mode on the C8F will go down by quite a bit as the battery drains.
The SP31A would only be using Buck mode if 2 CR123A’s are installed. They have low capacity compared to a high capacity 18650 so using those half cell sized batteries would be sort of silly. Am I missing something?
No. The SP31A uses an XPL2, which has a very low forward voltage compared to the XPL, and especially XPL-HI.
On turbo at 1000 lumens, it’ll stay in regulation until the cell voltage reaches 3,7V using most buck drivers with a drop out voltage of 0,5V.
On the 350 lumen mode, it’ll basically stay in regulation down to 3,3V, where most of the useful energy of the cell would be used, about 2,5Ah out of a 30Q, so almost all of the capacity out of the cell before internal resistance goes up, so the 350 lumen mode will stay regulated up until the cell is almost empty.
That’s also the reason the XPL2 is such a monster: it can draw a ton of current from a cell since its forward voltage is very low.
Using a very low voltage LED like the XPL2, Nichia 219C 90CRI, LH351D 90CRI, and E21A array are probably the only LEDs in which using a buck driver is actually very useful with a single 18650.
Have used dozens of those emitters, haven’t noticed them having such a low Vf, probably because I don’t give em the chance…
Bottom line is:
The highest sustainable output plus the longest runtimes will always be with a bigger light. It can dissipate heat better and usually has bigger batteries.
Generally speaking, go with the biggest light you can.
