For a review with better formatting, please go to my blog
Introduction
What was I looking for?
This is almost the perfect EDC AAA clicky flashlight around. I was looking for a light I can bring with me everywhere, everyday. And it needs to have a tailcap clicky because I was sick of twisty heads. I bought this in August 2015 and itās been clipped in my pocket almost everyday, which explains the nicks in the coating.
What do I love about it?
I love it for its brightness, form factor, and top notch quality. I used to have the Olight i3s EOS AAA twisty keychain light but I have sold that because it just doesnāt get enough use as compared to my Lumintop Tool. This is not a sponsored post - I just want to share my love for this little pocket rocket!
[Note: the tiny little clip at the tailend of the flashlight does not come with it. I attached it there so I can clip it to my pants pocket]
This was the packaging of the light - not fancy, entirely functional. My version came with just 2 spare O rings but the newer models come with an interchangeable magnetic tailcap.
Look at how well it fits in my palm.
Specs
These specs are provided by the manufacturer, and can be found here: http://www.lumintop.com/tool-aaa.html
Dimensions
Length: 3.16ā / 8.02cm
Body Diameter: 0.56ā / 1.42cm
Weight: 0.53oz / 15.02g (without battery)
Material
Aircraft-grade aluminium alloy with hard anodization
MSRP
~$18 USD (I bought it for SGD $35 from Fstoplights in Singapore)
LED
CREE XP-G2 R5 LED (CW)
Battery
1 x AAA battery (they donāt recommend using a 10440 in it but I have always used that and my light is still working fine. I never ever let it overheat)
Operating Voltage
0.9~1.5V
Modes/Output
[NiMH AAA] 3 Modes M-L-H:
32 lumens (4 Hours) / 5 lumens (60 Hours) / 110 lumens (30 Minutes)
[LiON 10440] 3 Modes M-L-H:
235 lumens / 59 lumens / 390 lumens
[Note: I did not measure these output levels myself as I do not have a light meter. I obtained these numbers from this thread: Lumintop tool - 10440 or not? | Candle Power Flashlight Forum Post #7]
Max Range/Throw
~ 47m (using NiMH AAA, more if you are using 10440)
PWM or CC
Constant current circuit (however, I do hear a whining sound on Medium and Low mode, but only when I put the light right beside my ear)
Waterproof
IPX8 (waterproof up till 2m, for 30 mins)
Lockout
Tailcap/mechanical Lock-out
Tailstand
No (due to the protruding tailcap clicky)
Lanyard Attachment
Yes, 2 attachment points but lanyard not provided
Quality
Right out of the box, I remember getting a good quality flashlight with
- Well-greased threads
- Responsive, tactile tailcap clicky
- Strong, reversible clip
- Clear, legible printing on the light in crisp white
3 years on, I still have difficulty removing the clip with ease because it has retained its āgripā so well. Also, I have never had the need to replace the tailcap rubber and O rings. The light is still waterproof (I tested it when I dunked it in a fountain to look for something that I dropped inside). It fits so well in my palms and the clicky response has never failed me in any occasions I have used it over the past 3 years.
Well-centred LED with orange peel reflector
UI
The flashlight has 3 modes. From off, hard press the tailcap once to turn it on. It will come on in Medium. Soft press to cycle to Low, then High then Medium again.
Medium ā Low ā High
Hard press to switch off the light. There is no mode memory, but if you turn on again within 3 seconds, it will go back to the next mode after the mode you left it at. E.g. switch off in Medium, turn on in Low.
This light has no strobe, beacon, SOS or moonlight mode as it was made to be an easy to use 3 mode light. I do wish that there is a moonlight mode (<1 lumen) so I can use it in total darkness without lighting up the entire room. Some of you might want a hidden Strobe/SOS mode for emergencies but Iāve never had the need for it and I do wish you have a larger secondary light for those emergency situations.
When I first used the light, I hated that it came on in Medium but then I realised that Lumintop made it such that it came on with a very usable amount of light. When I passed the light to my friends (non flashlight enthusiasts), they didnāt realise there were other modes so Medium was just right.
Beamshots
Taken on a Samsung Galaxy S8 set to manual mode: ISO 800, 1/15. Curtains were about 5m away. Level of brightness in the photos are very similar to what I saw with my eyes.
Medium mode
Low mode
High mode
Photo of the beam profile to show you the hotspot and the flood
I found that the cover of an old chapstick fits perfectly on the head as a diffuser, creating a nice beam, perfect for tent or bedside illumination.
Pros & Cons
Pros
Small light which makes it great for EDC
Insane output on 10440
Fantastic finish and strong material
Responsive tactical clicky
Strong clip
Great price
Cons
No moonlight mode
Cannot tailstand
No lanyard provided
No diffuser provided
L-M-H mode cycle would be better for some users
Conclusion
In conclusion, I am still in awe of this light that Iāve EDC-ed for 3 years. I did not imagine how much I would enjoy it when I was searching for a AAA clicky that could take a 10440. Lumintop was a brand that was fairly unheard of back then but I can now attest to its durability, performance and awesome price points (not just for this light, but for all their lights in general). There are definitely areas to improve on, as pointed out in the āConsā section above but these are minor issues that I am nitpicking on. However, if they can come out with a new version that addresses whatever Iāve mentioned, I would gladly pick one up since it will be the perfect AAA clicky EDC!
[This light was not provided for me to review. I bought it, loved it, and wanted to share about it. This is also my first flashlight review so I welcome feedback or a like and subscribe on my blog!]
