I have no idea how well they work (never had a reason to track a blood trail) but Bushnell makes the TRKR (short for tracker) series of lights. I bought one when Walmart was selling them cheap, I think mine is the 250 lumen model. There is a white LED in the center and I think three red and three blue LED’s in a ring next to the benzel. Only one color can be lit at a time. I only use mine for walks at a local nature preserve that requires a red light if you carry a flashlight.
I’m looking at the Bushnell, Gerber, Rayovac, and Primos blood lights. Amazon has a add on item light for $6.52 I will try, along with one of the Walmart lights.
Looks like very recently they got a reel of highest flux bin units, right now I see 1000 units of XPGDRY-L1-0000-00601 in stock and selling 'em by the piece. (^̮^)
Obviously quoted the wrong source when I wrote that 465nm is violet(blue).
But then again: I’m colorblind. Awkward.
A bit like Mendel, the founder of genetic’s and very reluctant sharing his own gene pool.
Did a bit more reading: the words Coleman light keep popping up.
Probably a good guess, maybe a little higher on DTP with a good lens. The lowest current I run one at is 700mAh and it’s behind the wide ledil CUTE pebble finish that Dale estimates to cause a ~33% optical loss and it measures 97lm in my light box.
Do keep in mind it will actually be much more power output than 97lm of white light, it can give you a headache pretty quickly. The cheap meters probably read narrow band color light lower than reality as well.
Might I suggest the royal blue XT-E. Same target wavelength as the XP-E2 but they’re designed to be extremely true to their binning. Binned into 2.5nm groups (so you can be sure that 465nm led you purchase will be almost exactly 465nm). Max drive current is spec’d at 1.5A (vs 1.0A spec for the XP-E2)!
Also the XT-E will throw better if you’re not planning to dedomed the XP-E2 (the XT-E can’t be dedomed and if you did dedome the XP-E2 it would then beat the XT-E in throw).
Thanks! They are offering right now free shipping to Canada with no order minimum. If I get the N08, then I'll have to get a star and then try and figure out how to mount the led on the star. Never did that before yet.
Dominant wavelenght range is 457.5 - 462.5nm for the 08 kit code. Quite good emissivity at 465nm thus it should provide. Closest kit code is 06 (460 - 465nm DWL range), but found nothing.
If you have never reflowed surface mount components it may be a good idea to ask for help if you have some expert at hand, or learn by yourself. Buy some extra spare blue emitters and maybe a bunch of cheapies to try and burn. Cheap copper MCPCBs here if interested.
Careful lay out of the solder paste, emitter placement, press down and paste excess toothpick removal, slow temperature ramp up and down, tight control of the temperature window, etc. There are some reflow diy videos out there, practice and calmness are good allies.
