A 24V psu even. Also I watched the temperature while heating the spring, it doesn’t drop one degree, so it’s probably a heat transfer problem. But I’m already using the biggest tip available.
When I cleaned off all the old solder and applied my Sn63Pb37, everything becomes so easy from there on. So I guess it’s a combination of the solder used (very likely lead-free, because it’s not shiny at all) and thermal transfer.
Or do I need any specialized flux or tip when reworking lead-free?
I wouldn’t assume that temperature readout is accurate in real time. If your transferring heat from the iron to the object then it should definitely drop down.
If the readout is accurate, then maybe there is not much heat transfer. Do you think it’s possible the factory soldered piece has some type of clear coating on it to protect it? If there’s a coating, it may be acting as an insulator. You might try scraping on the factory solder and then try to melt it.
No, the driver circuit requires the correct polarity to operate. You would need a special battery with the positive center on both ends like you get with a battery carrier.
Can somebody point me to website that sells a triple LED of any brand, already mounted on PCB in parallel, 3000K, 90+ CRI powered by 3.6v. All of those requirements are mandatory. I’ve checked all the most common places, I think, and find 4000k, 80 CRI, etc, but none with all of the above specs. Checked Virence, MTN, Intl Outdoor, Kaidomain. Thanks.
Alright so today I got to the point that I was ready to break stuff to find out how much force it needed to open this light. And oh boy, stuff did break.
I had to stabilize the needlenose pliers with some water pump pliers, because it started to heavily bend sideways. (it’s a Knipex btw, so ne cheap china stuff)
So I got the pill untwisted to like the last 10% and the driver popped out at that point. I could see that the needlenosepliers already dug so deep sideways into the PCB that components were removed.
Do I feel relieved now? Yes! Threw the light in the bin now and we both can rest.
P.S.: Same goes for my Lumintop Tool, there’s no way this unscrews without breaking anything. But I leave it alive for now.
The limiting factor is driver and pcb design. The boards and components can only handle a certain amount of current before burning up.
Aftermarket boost driver builders like Lexel and Richard at MTN E can squeeze about 50 watts from them. This is roughly 6A@6v and 3A@12v. So maybe 4,000 lumen from a 70.2 with about a 15A to 16A draw on a good 26650 high drain battery.
Most of the OEMS are not pushing the limits. They tend to put out 4A to 5A at the emitter and 8A to 10A on the battery which is why we see 3,000 to 3,400 lumen most of the time.
An interesting deviation from the norm is the new Nitecore TM10K which normally does 1,000 lumen continous, but has a 6 second burst mode of 10,000 lumen! This pulls about 35A from the Samsung 48G 21700 battery. I think they built a special circuit just for this one high output mode. The battery they use is rated at 10A continous and 30A for 10 seconds.
Alright so I got a new driver sitting here. Need to connect the e-switch. I don’t know which cable is which. Can someone explain it to a baby how to find the correct cables?
Edit: Ground should be near 0 resistance between one cable and ground on the board right?
It helps to say what driver and what light you have.
The e-switch is just a momentary switch that connects two wires. If there are no leds on the side switch circuit then polarity does not matter. Usually one wire goes to ground and the other wire will connect to a pin on the MCU that is looking for a ground signal.
