I did the same mod a few weeks ago with a 4000k 351D in a V11R. I sanded down a 16mm Noctigon MCPCB to fit and added a lighted tail cap.
Liked it so much I did the same mod to my V10R Ti.
Nice! I also thought about a lighted switch and to use it as a bedside light. Didn’t do it yet because of the low efficiency of the light and the small 16340 cells. Didn’t want to add parasitic drain.
Maybe I will still do it after I bored the light to fit 18350s.
Since I put a boost driver in my Jaxman Mini C8 (M8) I took that old 2.1A driver and put it in an old S2+ light with a Seoul Viosys Z5 UV emitter and ZWB2 filter.
First world problems, I know, but the filter is so good I cant even see how good or bad I centered the LED once the pill got screwed in. I guess it’s fine cause the beam pattern looks “normal”.
Having only used the Jaxman light a few times “stock” I forgot it has strobe and beacon in the normal mode group and I think you have to bridge some of those stars on the driver to change it. Any documentation on that somewhere? It’s a 7135x6 driver from Jaxman, has 3 stars on the board. Will bookmark that for a rainy day.
Not magically, but to be honest that”s not that difficult to turn an X2R into a triple…
I now have access to a lathe at work, but you could do the same with two 3mm alu or copper washer. (16mm and 18mm)
Then you have to file the MCPCB down to 18mm and voilà
I kept the stock driver :
1/ It has to be reliable and not burn pockets, so no high power FET based driver
2/ I wanted to keep the rechargeable function
3/ It’s powerful enough for my use
Nice mods CRX! I have a weak spot for that Ultrafire zoomie, ultra-cheap for what you get, well made and they have put a lot of thought in the design, only draw-back, for the size it should house a 18350 cell.
Is that RVS light an old-school light from dx back in the days? Fandyfire perhaps?
Yeah the Ultrafire zoomie is nice, compact chubby
I modded that one for an Efest 1200mAh 16500 cell so that’s much better too but I had to hack together the lighted switch from scratch.
That’s an Aurora SH-034 stainless steel with the blue lighted tail, cheap mans sinner Think I bought it from Manafont maybe about seven years ago or so, one of my first lights, very well made. I’m in the process of tarting it up for sale.
I’m just giving him a hard time because of how refined all of his finished products look. However, if you look at hot rod car types or some other hobbies I assure you the inside is not always all about “function” to some
