I'm looking for my grail light 0.7" diameter 500 lumen 14500 light
I have a Zebralight sc64c and it is as close to perfect as any light I’ve tried so far but the big disadvantage of it to me and all other 186500 lights is the width/diameter. That width makes it less justifiable for me to carry with me everywhere to the point where I find myself carrying a AA or 2xAAA light often instead. Thrunite T10 for the AA (I wish it was the T10T but they don’t seem to make it anymore) and Lumintop IYP365 Nichia for the 2xAAA for anyone wondering.
Anyway I thought 14500 light would be the perfect solution to this but it seems like all the 14500s I’ve tried have issues I find unappealing, primarily they are too thick, thick enough that it ends up making me question why bother when it’s only marginally less than the Zebralight sc64c. Prior to getting into the 18650 game my EDC was a Eagletac D25A Clicky. It is an amazing size and weight. The one I have is the Cree version; I don’t remember which Cree I just know I went with it because I wanted the most light and was tempted by the numbers and this was before I became a tint snob.
So far I have tried
  • Olight S1A - Bezel up carry, shitty button always turned on, cool tint, but good output
  • Lumintop Tool AA - Shitty tint, a bit thicker than I would find ideal, the pocket clip is entirely useless but otherwise this one came the closest.
  • Zebralight SC53c - Great tint. Decent output. Good UI. BIG FAT HEAD. The Head is so big it’s a bitch to actually use the pocket clip and the head is so large it’s not that much thinner.
  • Thrunite T10 - It’s the NW version. The tint is good but not great and it’s a bit thick. Not super thick but still thicker than I’d like.
  • Reylight Pineapple - too heavy and too thick. It’s a good length, has a great tint, has the good output. The UI is good but not great.
What I’d like:
  • 14500 light around 0.7” in diameter and around 4”ish in length
  • Max lumens at or greater than 500 lumens
  • Moonline mode 1 lumen or lower
  • Several modes in between
  • Good warm tint around 4000K
  • Preferably a high CRI
What options do I have outside of modding? And if it comes down to modding how do I even begin with it?
They changed the UI slightly from when the review was posted. The updated UI is described in post #17 and” is now in the sp10a.“:Page Not Found - Aliexpress.com
”The newest sp10a v2 has one more mode for a total of 6 and a .5 lumen fire fly”:Amazon.com.
If you would like a better tint reflow a LH351D 4000k 90cri led on the existing board. Not hard to do but requires soldering.
I’d grab a Ultratac A1 and swap in your emitter of choice. It’s right at your requested .7” Which the Lumintop Tool AA is as well. It’s also shorter than 4”. Has a good sublumen mode with NiMh. Don’t know if you are going to find a AA light with “several” modes in between. Your .7” threshold might hold you up as well. The battery itself is 14mm, plus or minus, depending on wrap thickness. That only leaves what a little over 3mm for tube material and tolerances. Head and tail sizes are what they are based upon the size of drivers being made now days. You may have to sacrifice something if you are looking for AAA type thin in a AA light.
That’s thicker than I’d like and a proud side switch seems like a really poor design choice but appreciate the option.
If I have to remove any qualifiers it’s not my grail light anymore, it’s just another light. The Reylight has 4 modes. Moonlight, Low, Mid, High, that’s several so I don’t know why you say several modes is going to be hard to find. The Zebraligt has like 16 output levels you can program it with I think.
The Eagletac I’m referencing as almost my perfect size is Head Dia. 0.7 inches (17.5 mm) Body Dia. 0.65 inches (17 mm) so I guess 18mm is ok but any larger and it gets to the place where I’m not interested.
Well, I hope you find what you are looking for. Might want to find your perfect host light. Whatever that may be and add your own driver, emitter and reflector. I don’t have a Eagle Tac so I’m not sure how it’s put together. You may just be able to swap the emitter out for less than a 10 dollar bill and have exactly what you want. That is what I would do if I couldn’t find anything commercially available.
If size is important, the DQG Tiny AA runs 14500 and comes in a variety of emitters including a warm 90cri Nichia. Not much bigger than many AAA lights and easy to carry.
FWIW, my pocket EDC rotation includes the even smaller DQG Slim AA which is a half sized AA light.
Which Eagletac model are you interested in?
The Ultratac A1 is quite a nice light too and small. If I had the same request you have from a small 14500 light I would choose the A1 and mod the driver and led. I’m currently working on fitting a Mtnelectronics 17mm boost driver in a A1 with a high cri xhp50.2. Should make 2000 lumens (hopefully) using a IMR Efest 14500 at least until it starts blistering my fingers. Hopeing the cell can delivery 7 amps for a few seconds. :smiley:
Please tell me you are going to detail that mod in a thread on here. I have several A1’s new in the box and that just sounds like fun right there. :slight_smile:
I might :smiley:
I haven’t took any pics or anything yet, so I may have to get it operational and disassemble to take some pics to post up. I’m at a stand still right now, I think I shorted something while I was testing on my power supply and blew the mosfet. Ordered a new mosfet and reflowed it back in its place and now the drivers still acting weird. Waiting to see if Richard has any ideas on whats going on with it.
Noway I could keep a 14500 pocket rocket a secret. :smiley:
I use an Eagletac D25A with a 14500 in it. Only problem is the mode spacing gets a little weird. Probably like 5-150-300
I agree with you about the width of the light being important. I carry a thrunite T10 on the inside front pocket. You can see my mods here. Edit: the deep carry pocket clip is also a big plus for me.
It sounds like the D25A is the right size, but it’s not bright enough and the tint is bad? To mod it you first have to take it apart, and this can be the hardest step because some manufactures use glue on the threads. Then I would use a FET+1 driver for use with a li-ion 14500. This will get you a low moonlight and also very bright turbo. Mtnelectronics has some small diameter drivers that might work for your light. Also switch out the LED for one of your choice on the correct size DTP (direct thermal path) MCPCB. Once you get it apart and post pictures we can help with part selection if you’re not sure.
I remember looking at many AA/14500 lights before I chose the T10. As you noticed most are too thick and/or use a side switch. So modding might be the best option to get all the features you want.
Excellent. Hope you get the mosfet problem sorted out. I know the basics of how a mosfet works but thats about it. I wouldn’t be any help figuring out that problem. Well now that the secrets out of the bag I will probably bug you until you get tired of me and post all of your hard work so us lowly beginners can plagiarize your work. :wink:
Eagletac ti d25A early version (2012) does 600+ lumens on an old school xml
The Xeno ES1 is the same size width/length too .I like these lights because of their quality and I agree with you it's a good size AA light.
They also share the nifty Xeno diffuser with a flat top .one of the few wand diffusers i actually like .. it fits the eagletac like it was made for it.
The ES1 is listed as a AA only light and has the Olight style.. med /low high driver...but has the best looking tint cree NW 3B I've ever seen ..and I've seen a lot of bad 3B's :P
the low is one lumen which I like
Good luck on your quest ,Sounds like you'll need to mod a light
It’s the Eagletac D25a clicky that I have. It’s a very cool tint but for size that is about perfect. Maybe a bit longer.
I’ve never heard of Xeno. It looks like a good size I just wish it had more output.
D25a ti nichia 4000k comes close to all you want.
They apparently don’t make it anymore and I don’t think it will allow 14500 or get the output. Is there a mod I can do?
My opinion to achieve what you want.
I don’t know the size of the driver, so a 15mm Mtnelectronics driver with 4 7135’s might work or 17mm with 4 7135’s removed filed down if its 16mm.
I think 4 7135’s will work with a nichia or samsung led in a high CRI to get you to the 500 lumen mark. 4 7135’s will give about 1400ma except on the 17mm driver, 4 will give about 1490ma. Its possible with the 17mm driver only 3 7135’s would be needed to reach 500 lumens depending on the led you use. I prefer the Samsung 4000k LH351D 90 CRI. The drivers from Mtn have different UI’s you can chose from.
If the D25a is your chosen size light but lacks other features, then modding it should get you your holy grail. :wink:
For most of us modders that’s the whole reason we do it, we can’t buy a light exactly like we want it. :smiley:
The L3 L10 clicky would be a potential mod host of you didn’t want to mod the D25C.
What kind of tools would I need to do something like that?
That looks like a neat little light.
