Pre-sale: ReyLight Triple Ti Dawn 18650/18350 triple
Pls check here for the driver.
Middle section can be removed to use 18350.
Copper pill and MCPCB.
Not glued.
Regular production.
Good to see the improvements!
Does the driver do thermal regulation? Which is kind of important on hotrod titanium flashlights?
Enjoyed the last light from you but was battery size sensitive so,are springs better in this model and 3400 were a no-go!
I can’t decide between the machined finish and the stone washed finish… Any chance for a black-washed finish?
May we see renderings of 18350?
Rey, I have several of your lights and I love them. The Ti Lan is absolutely my favorite AA light. I want to ask for this one, is the head mcpcb swappable with a noctigon triple mcpcb? Also do you plan on making copper version? I think for 18650, the heat might be a bit much for TI and copper would be perfect.
I tried to visit www.reylight.cn to get a better idea of what the different body and clip finish options looked like but the site has apparently been hacked.
Rey, if it’s going to take a while to get it up again, can you post some more pictures here?
When you say the head holds 9 or 15 trits, are there two different drilling patterns, or are they all drilled for 15 and some only loaded with 9?
Also, the internal BLF link to the driver info in post #4 above isn’t working for me.
Maybe we can find more driver info here.
Won’t happen again, haha, I will make a list.
Sorry, no black-washed.
It is same size as noctigon triple mcpcb, 20mm dia. Copper version, not sure yet, might be a very future plan.
Here it is.
Yes, I will post more pics.
15 trits, slots around head are drill more closely then the 9 trits.
post #4 link revised, thanks.
In for one
Is it possible to get one with a simple UI for those who don’t want to have to program their lights — low/medium/high, for example?
The UI default is 3 mode. LMH.
Thanks!
How about some photos that label which finish is which, please?
yes it has thermal protection :slight_smile:
If you can only pick two, in addition to machined, who should choose? :person_facepalming:
Looking forward to more data and detailed photos.
