Not OP but mine came off very hard.
First I tried with my hands, silly me.
Then I got some strap wrenches, and tried putting one on the head and one on the body, that was a no go, almost broke the smaller of the two wrenches.
Then I tried putting the body between a wooden door and it’s frame, like I did to get my H03 apart before I had wrenches, that didn’t work.
So then I finally remembered my neighbor has a vice, facepalmed the inside of the back of my skull, and headed over to his house. I put the body in the vice between some towels, and I pulled and twisted and pulled until I was literally beginning to lift the entire 3’x6’ steel frame table off the floor… so I braced my body against the table and tried again, and she finally let loose.
Impressive! Mine wasn’t nearly as adventurous…I removed the button so I had a nice flat surface to put in a vise (between two pieces of soft leather), and with some gentle but persistent persuasion with a strap wrench, it eventually broke free.
I actually broke my wrench when I tried to open the GT. Thing I have to give up the conversion to GT70 now... probably will just break the vice of my Grandfather if I try again to open this Monster :D
Actually came off with only a 5 minute fight. I had him on the ground, and I was pummeling his head with a large Craftsman strap wrench(the rubber straps are new and nice and tacky). I uttered a few vulgarities and put him in a half Nelson. He groaned for mercy, I cursed again, threw all my weight upon his neck, gave a loud yell, and ripped his head off. Not a mark on him, but he was broken, in just the 2 pieces I needed.
Do we actually need new battery carriers for the conversion ? PossiblyDue to some voltage change?
No.
Lumintop tried to reduce the resistance in the springs by tighten them. They made the aluminium base thicker and shortened the rods.
But protected batteries won’t fit any more.
(Protected are recommended for safty and legal reasons: Remember you have 8 chances to put a battery wrong into a cartier. If you use unprotected you should know what you are doing)
I broke my wrench as well! Lol. The fact that I bought it for 3$ from china didn’t help either. But mine broke just as I cracked the head open. So 3$ well spent I guess. Waiting for the conversion kit now.
Mine will never touch oil. I learned the hard way, I keep mine dry and sealed in a ziplock bag, lest they dry out and become brittle and slippery, and not very useful. My oil filter wrench has rotating iron fingers, that the harder you turn the harder they squeeze the filter.
4 bucks at walmart( hyper tough brand) works great
With the change in the carrier design would it be a bad idea to use one new design and one old design in a light at the same time? Not that I would ever want to but how worried do I need to be in case they ever got mixed up or if one broke and replaced with the other type?
