I just tested all my 26650 batteries, all of them works fine with my original NA40.
Where did you buy this NarsilM driver?
Appearantly DEL built it for him. He made it himself based on Del’s design.
If you want to buy one ready to go you can see Lexels thread on them.
if I followed correctly you did report that to Neal too and he already sent you the replacement?
I just got the replacement tube from Neal. :+1: I think it was the springs. The springs on this thing can get crushed easily. Otherwise I really like this light. It has good mass for heat sinking. I measured 3,970 lumens at 1s using freshly charged shockli 26650 5500mah on my TA lumen tube with Maukka calibration.
I think the light output is being severely limited by the springs. They are probably phosphor bronze/BeCu short springs can carry quite a bit of current, especially if it’s really stiff, meaning it has very low contact resistance initially.
The problem however is that it takes into account if the light is new. Pure copper oxidizes very quickly, meaning contact resistance shoots up dramatically, and even faster with heat, which can great hot spots, and contact resistance goes up because of heat.
Using gold plated springs, or even better, dual springs, would help a ton in this regard.
You are probably right. The original springs that came with the NA40SE is very thick. The replacement is thinner with more loops, which I’m guessing is from the version 1 NA40.
Seems quite bright for 3 emitters. :+1:
My xhp70.2 (4 emitters) and FET driver with 2 x 26350 got 4100lm measured similarly. I bet using that single Shockli is way better than my 26350 cells.
This NA40 would be pretty sweet with a better UI like Tom E used. You retain the charging as well. That’s one advantage compared to building up a C8F 21700.
Did you happen to measure how many amps it’s pulling across the tail cap on turbo?
I don’t have the equipment to measure amps.
I’m waiting for my Nightwatch heavyweight XHP70 light to come from Enogear and see if the NA40 tube fits. That would add USB charging to that light.
If you ever want to:
For tail cap amp draws, all you need is a $30 UNI-T UT210E clamp meter. That's the model a lot of BLF folks use due to the big Group Buy back in 2016.
The process looks like this.
The UT210E can also measure voltage.
my NA40 pulls nearly 15A with fresh 26650 cell, so my wild guess is about 5000lumen
the light is also equipped with temprature control, because the turbo last much longer when using this light under water
For anyone who is waiting for this light, available stock is coming back on Taobao on 10th Oct 2000h, beijing time.
Anyway, more details and more pics can be found in the Taobao item’s review section, which number 410 reviews.
From my perspective a far more interesting question about this light is the power source. It is shown a single 26650 battery, and to deliver 6000 lumens, is going take 20 amps if not a little more, and there are not a lot 26650’s out there that can sustain 20 amps for a long period. The more output you want, such as from xhp50.2, the more power you need. 10,000 lumens is going to require 30+ amps, and if you thought 20 amps for a sustained period was difficult, 30 amps is much much worse, and in either case, the heat dissipation is going to be very big problem, very quickly. The Keeppower IMR 5200mah according to HKJ’s testing isn’t good for much more than 20 amps.
Yes, that’s probably the reason why folks aren’t getting much comfortably above 4000 lumens, much less hitting 6000 lumens.
A single cell gunning 6000 lumens at very high amps is going to place a lot of stress and emphasis not only on the 1 x 26650, but also on the springs, the cleanliness of contact points, all the components in the power path.
You cannot use the Keeperpower 26650s, they are like mid current cells only.
The best Keeperpower 26650 vs Liitokala INR26650 @ 20A “only”. I think we need to look at 30A (see subsequent posts).
And this is the VTC5A vs Liitokala INR 26650 @ 30A. Sony VTC5A wins
To get the absolute best measurements at start-up or within 1-20 seconds, i guess you’d need the true heavy hitters.
Bring out the Samsung 20S INR (Vapcell 2000mAh black)
Samsung 20S vs Sony VTC5A @ 30A. No contest.
Yep. To get this power out of a single cell, it is imperative to reduce resistance as much as possible.
The biggest one here is the spring. Why aren’t they using dual BeCu springs, or at least, a coated spring? Uncoated copper alloy springs will develop oxides on the layers overtime, boosting contact resistance, and creating hot spots, and boosting the voltage loss even further.
That means even if they are using the highest conductivity BeCu C17500, performance will get worse over time.
Look at djozz’s test on the SST-40. In the best scenarios, cooling and excellent bins, it needs 6A per emitter at 2000 lumens. If you want 6000 lumens OTF as measured in all of our ceiling bounces/lumens tubes/integrating sphere, you’d need much more after factoring all the lens losses, driver losses, heat etc.
Probably need 2400 lumens in dijozz’s test if there is a 17% loss to 2000 lumens OTF, thus 9A per emitter.
I am guessing 27-30A at the tailcap is gonna be needed, a fair bit of which is really heat and not lumens. Don’t even dream about efficiency once comfortably past 6 amps per emitter.
Definitely 12awg copper bypass for this jobbie, just strip the insulation and do it. Enjoy the smoke if the light does puff though.
Hmm 12AWG bypass over 1cm.
At 0,052mOhm of resistance, wouldn’t you be trying to pull, at 3,6V average voltage, about 69 000A if there were not other resistances in the circuit, including the cell?
Yeah. Maybe you’d kill the emitters if there was a 6000mAh version of the Samsung 30T and bypasses everywhere.
Seriously just look at other “6000 lumens” lights measured in our ceiling bounce/tubes/spheres, like our ubiquitous BLF Q8 with 4 x XP-L.
Of course 4pcs of XP-L (at 1500 OTF lumens) is going to be much more efficient than 3pcs of SST-40 (at 2000 OTF lumens each). But even so, we are talking like about 25 amps for the 18650 in 4P config? Or is it closer to 30 amps?
This is a 30A light, if you wanna do 6k OTF lumens, low 20-ish if you want to gun at 5k OTF.
At *0,052mOhm*of resistance, wouldn’t you be trying to pull, at 3,6V average voltage, about 69 000A if there were not other resistances in the circuit, including the cell?
LOL…… We need to get the bottleneck out from the tail-end for sure.
Actually thinking about that, we use 2.5mm diameter copper wires here for our 240AC. That’s thicker than 12awg. More like 10awg.
Just thinking of a very common and convenient source. And seriously speaking, the 10awg stuff that some electricians source for is sucky……that’s why some of our local setups with air conditioner wirings doing higher currents might cause degrade and subsequently cause fires over time etc.
