Sounds like the 7135 is fried on the driver… have no idea how it could have happened unless there was a short initially….
Stupid question probably, what would happen if someone put in 4 xhp35 emitters for more throw would that work in this kind of light vs the xpl emitters?
In this case, it would just be better to swap the XPLs for XPL HIs for more throw.
You will get more lumens and more throw with XHP35HIs, but you will need a different battery configuration and a buck driver, which will cost quite a bit.
yea ok, makes sense. i feel the xpl are more then enough anyways.
I’ve not posted here in a while, but I think this is the right thread. I’ve been playing around programming my Q8 (Narsil v1.0 I think) and now have a couple of weird bugs… It’d be great if someone could help me out with a fix.
If I am in ramping mode, and I press and hold then I get a flash of turbo (about 0.5 seconds), before it goes to moonlight. It’s as if the light forgets it’s in ramping for half a second and goes to what it would in the mode groups setting before it remembers what it should do. I should also say this only happens if the light hasn’t been on in the last 10-20 seconds or so, if it was recently switched off then a long press will go straight to moonlight.
There is also a probably related issue when using mode groups. This happens in similar circumstances as described above (switching on after 10-20 seconds of not being used). Here, the light comes on in the correct mode, but the indicator (under switch) LED blinks three times and the light turns itself off again. If I click a second time during the three flashes then it will usually stay on instead. This one will also sometimes happen twice, i.e. another time after turning the light back on again. I haven’t seen it three times before though.
I had thought I’d caused this by changing a setting, but I have tried switching most back to factory resets and the problems are still there.
Does anyone have any idea what is going on?
Right, I’ve actually just fixed it.
I feel a bit silly now, I’d been trying what felt like everything for the last hour or so before posting, but I hadn’t reset the step-down setting to timer instead of temperature. Doing this fixed both issues. I’m not sure why exactly, I’m guessing for the mode groups at least there was some fault with the sensor that caused it to shut the light down. I have no idea why this would also cause turbo from press and hold in the ramping setting.
I’ll leave it on timer now!
Hi, good to see you’re still around.
I’m not sure how to exactly explain what happened to your Q8, but if you set the stepdown to temperature instead of time, the default stepdown temperature can be anywhere, including room temperature. That is because the temperature is recorded in the MCU and that is extremely inaccurate. So you will have to tell the MCU the correct stepdown temperature by going through the stepdown temperature setting procedure (see manual).
But going back to timed stepdown is a good choice too, the 3 minute default is about spot-on IMO when batteries are full.
Hello,
Who can conduct a temperature study?
To what temperature does Q8 head warm up at room temperature (22-26C) without forced cooling after 20 minutes of operation ?:
- 1500LM (Group4)
- 2500LM (Group6)
- 750LM (Group8)
Is there a 20-minute decrease in brightness for thermal control in these modes?
Thank you!
1) No thermal stepfown from what I tested.
2) Still nothing.
3) Still nothing.
The only decrease in lux comes the battery voltage going down as time passes
Thanks, you too. I somehow finally managed to get away from buying new lights and more into using the ones I already have! I still get drawn in by the odd-BLF special (I really like the look of the Sofirn AAA light with the Yuji LED and I’m sure will pick a few up after the first feedback on them), but the BLF A6 and Emisar range pretty much killed off my feel for needing anything more.
I did set the temperature using the procedure on the instructions, and I waited until the body was really too hot to touch, so I thought that wouldn’t be the problem. I would have to guess that my thermal sensor was particularly inaccurate, or faulty, leading to the odd behaviour. I think timed stepdown will be fine. It’s not like I regularly need 4-5k lumens for more than 3 minutes at a time anyway!
I’m not sure if it’s the same issue, but I fixed something like that in RampingIOS between V1 and V2. If the user ran the light on a high mode for a while, then shut it off, it didn’t reset any of the thermal info it had collected. So when the user next turned it on, even at a low level, it would think it was hot and then “step down” to whatever it was going to do in the previous session, and this usually meant it would go from a low mode to a high mode.
Since RampingIOS V1 was a fork of Narsil, Narsil could be doing something similar. It wouldn’t be the first bug the two firmwares have shared.
I completely rewrote all that for FSM / Anduril / RampingIOS V3, and those also allow the thermal sensor to be calibrated. So, that’s available if you’d like the issue fixed instead of just working around it.
I resolved the issue. I guess I used too much solder paste or I moved wrongly with some led and there was a problem - straight anode-catode short. I reflowed leds again and all works fine now. Thanks for ideas anyway ;).
After these “troubles” I have really nice 4000K HI CRI beam of LH351D leds and I got a lot of new modding experiences :).
The BLF Q8 is not available on BG,when back?
Processing time:Expected on October 31, 2018
just in time for halloween.
You can try Sofirn Q8 on aliexpress or amazon
the sofirn is coolwhite emitters tho, perhaps he want the original ?
Does anyone have good sources for a diffuser for the Q8? A warm colored one would be perfect.
Fenix AOD-L.
I have a problem. After removing the batteries (for charging), the flashlight forgets the custom setting of the temperature of the temperature control and uses the factory setting of the temperature of the temperature control.
What to do? Or is this the norm?
There is a bug in the software that shows up on very few lights where it doesn’t always save changes made in the menu after battery power is reset.
Iirc it will remember eventually, it may take a few tries plus it helps to cycle the light on/off and basically use it normally before disconnecting battery power.
I think it’s referred to as the Narsil memory bug.
