Barkuti
(Barkuti)
September 29, 2018, 10:02am
14
When faced with the need to use a 5050 reflector centering ring over a 3535 emitter, I've succeeded by carefully glueing the centering ring over the emitter board. This glue (for example) works well and any excess is easily cleaned with alcohol.
Cheers :-)
Niko
(Niko)
September 29, 2018, 10:08am
15
Thanks for idea but other center rings are too high for this emitters. Is not easy shave to focus
Barkuti
(Barkuti)
September 29, 2018, 10:33am
16
Sanding down the centering ring is an option. A bit of trial and error may be involved, of course.
Cheers :-)
djozz
(djozz)
September 29, 2018, 11:35am
17
When in the business of changing leds in flashlights it is unavoidable to master the art of re-shaping centering rings
Looks like they listened to us! A bigger package improves the performance .
This will probably go in my big thrower. I had been planning to use the LED Enderman mentioned, but this one will be even better.
djozz
(djozz)
September 29, 2018, 12:44pm
19
And they introduced a neutral thermal pad! Now some praying for the Lumileds 4040 lay-out.
The_Driver1
(The_Driver)
September 29, 2018, 12:50pm
20
The other new Osram LEDs that Enderman mentioned already have that. That’s no surprise in this regard.
DavidEF
(DavidEF)
September 29, 2018, 1:20pm
21
Enderman:
That sounds amazing, 200cd/mm2 stock should be like 300+ once we overdrive it on DTP MCPCBs
Can’t wait, this will be a serious upgrade over the lack flat, unlike the CSLNM1.TG which is only a slight improvement.
However, it will be many months or several years before we can actually get some of these LEDs.
The CSLNM1 isn’t even available yet in multiples less than 1000
Regardless, laser phosphor is still a better option for ultimate throw.
This LED will be good for normal LED flashlights.
Multiples of 1000 you say? If it’s worth it, BLF can pull off that quantity easily in a group buy. It is rare to see that many bare emitters bought in a GB, but if this new one is as good as it might be, I don’t think 1000 or even 2000 pcs is a problem to reach.
DavidEF:
Enderman:
They do this because the LEDs are not available yet. We just need to wait.
DavidEF
(DavidEF)
September 29, 2018, 6:33pm
23
OK. I must have misunderstood. I thought Enderman was saying that the CSLNM1 are available, but only in qty 1000 or greater.
Is this a 3v led? Being designed for the automotive industry that wouldn’t be my first guess. Why is “boost” in the name?
Enderman
(Enderman)
September 29, 2018, 7:31pm
26
Yeah the CSLNM1 is available in 1000+ but there’s no point in doing a group buy for that one when this HX is almost certainly better in every way.
More lumens AND more intensity
Barkuti:
LoL!
Lol fixed
It is, same as all their other automotive LEDs like the black flat and the others they make.
This LED will be THE LED for throwers. It’s alsmost perfect (integrated copper pcb would be perfect). No more 12V XHP-35 HI LEDs!
Here is the datasheet.
The brightness curve is very steep. It might even go up to 15-20A.
But unfortunately we will probably need new pcbs for it.
DavidEF
(DavidEF)
September 29, 2018, 8:03pm
28
Yeah, I was remarking that if they do the same with this HX, it would be worth doing a GB in order to get them, instead of waiting until smaller qty orders are available.
Enderman
(Enderman)
September 29, 2018, 8:48pm
29
DavidEF:
I would certainly be down for that
Brightness @ 6A: 1320 - 2010lm
Luminance @ 6A: 220 - 335cd/mm^2
Vf @ 6A: typ. 3.35V
official maximum current: 6.6A
The waiting for this is gonna kill me .
Geuzzz
(Geuzzz)
September 29, 2018, 9:03pm
31
This looks very nice. Was planning a flat black in my D1s, but now I will wait for this.
EasyB
(EasyB)
September 29, 2018, 9:06pm
32
I couldn’t get the datasheet to open. Is the range you have there from different bins? Low forward voltage too, making it possibly a good match for direct-drive multi-emitter high output throwers.
Yes, it’s the entire range of all the brighness bins. The amazing thing is that you can still overdrive it…
