Yea maybe $20 USD for you for 4 x 30Qs on sale, "But" for me $28.20 Australian for 4 x 30Qs, A fair while back they were only $23 for 4 of them & so i bought about 32 of them & haven't seen them as cheep again since.
For us(we) Amazon US purchasers, I see only two reviews. I know we all said thank you but I think Sofirn was hoping for a whole bunch of verified purchase reviews. I wrote one of them. I suppose anyone who received one is having fun all night (thanks to the high capacity) and sleeping all day!
I sound like a broken record, but 5775.3 lumens is what I get once again on a brand new just took it out of mailbox Sofirn Q8. Rested 30Q cells at 4.19V. Literally dropped in the cells and put it on the light box, first time I turned it on.
TK? I flashed Anduril on this new Q8 with the exact same result, no side switch back-light. Zero modification to the light other than flashing Anduril. And to be sure my file was clean I downloaded it fresh from your site and installed this new file. Under lockout condition, tap-tap-hold only gives me momentary moon level. No blinks or anything else. Testing functions shows Anduril working perfectly, as before.
Maybe y’all can help me on this, I will be modifying this second Q8 soon and the plan was to use SST-40’s for something in the range of 10,200 lumens. (Done it before) But I like doing things different, so now I am wondering if it would be worth it to use XHP-50.2’s and see if I can get 16,000 or more from this Q8. Am even entertaining the thought of building a top end extension fitted down into the Q8 head with cooling fins above the existing head to aid in heat management. Probably wider than the stock head at these new fins. Thinking to just use 4 pairs of 18350’s, run time would suck but it wouldn’t be used for long periods anyway… I already have the new MCPCB’s, SST-40’s are en-route, don’t have the 50.2’s. What say ye?
The Q8 ramping mode blinky settings has me confused. Double click to turbo, double click to strobe…then what ? I have tried single, double, and long presses and I can get it to change strobe types sometimes but not with any consistency, Also , it doesn’t memorize the change for next time. Should it remember the new strobe setting?
you can’t dilly dally when in strobe, as soon as you enter it, you need to click to the strobe mode you want, single clicks, within 1 second or that mode will lock in….
unless you got a defective light but i have never heard that particular issue.
& no, it doesn’t save strobe settings.
