JasonWW,
Thanks Jason that makes perfect sense,i just told him on phone what you said & now i'll send him the banggood link to the samsung 30q batteries.
thanks again.
JasonWW,
thanks again.
Right now 4 x 30Q button top batteries are on sale for $20. Not bad at all. I might grab an extra set for myself.
@ JasonWW,
Yea maybe $20 USD for you for 4 x 30Qs on sale, "But" for me $28.20 Australian for 4 x 30Qs, A fair while back they were only $23 for 4 of them & so i bought about 32 of them & haven't seen them as cheep again since.
For us(we) Amazon US purchasers, I see only two reviews. I know we all said thank you but I think Sofirn was hoping for a whole bunch of verified purchase reviews. I wrote one of them. I suppose anyone who received one is having fun all night (thanks to the high capacity) and sleeping all day!
I will write reviews today.
Just summit 5 stars review on amazon.
I sound like a broken record, but 5775.3 lumens is what I get once again on a brand new just took it out of mailbox Sofirn Q8. Rested 30Q cells at 4.19V. Literally dropped in the cells and put it on the light box, first time I turned it on.
Hmmmm... Nice!
TK? I flashed Anduril on this new Q8 with the exact same result, no side switch back-light. Zero modification to the light other than flashing Anduril. And to be sure my file was clean I downloaded it fresh from your site and installed this new file. Under lockout condition, tap-tap-hold only gives me momentary moon level. No blinks or anything else. Testing functions shows Anduril working perfectly, as before.
Maybe y’all can help me on this, I will be modifying this second Q8 soon and the plan was to use SST-40’s for something in the range of 10,200 lumens. (Done it before) But I like doing things different, so now I am wondering if it would be worth it to use XHP-50.2’s and see if I can get 16,000 or more from this Q8. Am even entertaining the thought of building a top end extension fitted down into the Q8 head with cooling fins above the existing head to aid in heat management. Probably wider than the stock head at these new fins. Thinking to just use 4 pairs of 18350’s, run time would suck but it wouldn’t be used for long periods anyway… I already have the new MCPCB’s, SST-40’s are en-route, don’t have the 50.2’s. What say ye?
Go for broke, get the most out of it you can.
I would say just wait for the extension tube for the Q8.
You’ll get 8x18650 compatibility and the ability to draw massive power levels. And much higher capacities compared to 8x18350s.
……… POOF!
Kawi , I had three in my scratch build that drew 21A at 13,000+ lumens, no poof!
The one in my Jaxman is making 3000 plus on two 14500’s. Think it’s at 3A or so in that light.
Djozz has tested them up to 15A.
But yeah, there’s that possibility which is why I asked. The Quad set up may make the difference, don’t know…
Either way though Kawi, I’ll have 4 more HI’s you can have…
The Q8 ramping mode blinky settings has me confused. Double click to turbo, double click to strobe…then what ? I have tried single, double, and long presses and I can get it to change strobe types sometimes but not with any consistency, Also , it doesn’t memorize the change for next time. Should it remember the new strobe setting?
I don't think so. You do have to keep on clicking till you get to the Blinky you want.
you can’t dilly dally when in strobe, as soon as you enter it, you need to click to the strobe mode you want, single clicks, within 1 second or that mode will lock in….
unless you got a defective light but i have never heard that particular issue.
& no, it doesn’t save strobe settings.
Hard to tell which strobe mode you have switched to if you have to click within 1 second in order to keep switching.
Yep, it is. :+1: . . To eliminate this problem just memorize/remember the number of clicks it takes to go to the strobe you want. That way you do not have to ‘see’ it to get there.
