Yes, most definitely.
I was in contact with Thorfire and they said the minimum order quantity would be 100. I want a SS bezel because I like to put my lights lens down when they are top heavy. The stainless would protect noticable scratchs from happening.
Will this fit the original S70 as well?
Caleb, I’m not sure. Someone that has both models (S70 and S70S) should swap the original aluminum bezels to prove that it is the same design and dimensions.
Interested in 3 pcs.
Thank You
I can confirm that S70 and S70S have the same design and dimensions bezels.
baldo21, great, thank you for that info. I have you down for 3 but need to get to 100 to make it worth it for Thorfire.
I don’t have an exact price but if I can get 100 units demand I’ll contact Thorfire and let them know.
in for price
I need 1.
JozzV6, alright I have you down for 1. If we can get to 60 I’ll probably be able to recoup the initial cost if I charge slightly more than the unit bulk price, which is unknown as of now.
Great! I assume that means that the threads are the same and the bezels are interchangeable?
If so, then I’m in for one.
Cheers!
Yes, that is correct.
Swapped out the JAX X6 Hunter SS bezel with the S70… a while back
KawiBoy1428, that looks so nice. It was the Jax x6 Hunter that inspired me to look into the stainless bezel. I tried to find replacement bezels for the Jax, but to no avail. The one you show in the image is smooth, and I was hoping to get one of the same design of the Q8. I think that design would look good on the S70 line.
I would be in for 2, for my X6 Hunters…
I’d buy one for sure
Kawi, I have you down for 2
RobertB, have you down for 1.
Thanks everyone.
I would be in for 1.
vinte77, I wrote you down for 1. Be sure to vote to make it look better to Thorfire.
