Ok it’s more like usd 113, not usd 100. (there is a rmb 100 coupon voucher, can see it when you add to cart) https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.169.702a7484WP4sMa&id=538622408534
We then consolidate it with other stuff and ship it over, for normal goods it’s quite cheap even by China standards. Folks in HK, Taiwan, Malaysia etc do it this way from Taobao.
If we are lucky, we might see some Taobao sellers offering either a 10% or even 20% discount on 11/11 singles day, which is a very very big thing in China.
It’s not tooooo bad, esp if you do not own the BLF Q8 or something. \
Do a ceiling bounce test and see what it can do.
Unfortunately in this case, it’d be very difficult to dispute via Aliexpress’s ESCROW service to get a partial refund. You can try though, if you have the time and can prove with pictures that the LEDs used are not XHP 70.
I believe it’s quite unlikely even though Cree’s spec lists it that way (the chinese usually don’t do it such a way), even the chinese specs show it as 6V 2500mA and 12V 1250mA, 1500-1900lm. 15W
It’s most probably not a 30W emitter, efficiency performance aside.
Mail’s in! No batteries until this evening. Got my LX1010BS Portable Digital Lux Meter at the same time so will put this next to BLF & Sofirn Q8 and see how we go.
Edit: First impression, it’s brighter than Sofrn Q8. Will have to wait until it’s dark to do an amateur ceiling bounce. Sure gets hot quick!
Bro! Please do that! Am sure many people would be interested. First impressions seems somewhat ok, though it’s not the 9000 lumens light it was meant to be (never mind the Taobao 13000lm thingy).
By the way, pls also do a ceiling bounce with the BLF Q8. I think i read somewhere that sometimes these ceiling bounce tests might favour the more throwy lights and the Sofirn has 2X the cd over the BLF Q8 which in turn probably has 2X the cd of this light.
And besides, it’s in NW (though not high CRI), so how bad can that be.
PS. What batteries are you using? For sure these need at least Samsung 30Qs.
And if you are saying that it is getting hot quick, it might be gunning those pretty hard. Might even be able to squeeze out more with just simple spring bypasses.
edit - actually in some Taobao links, i am seeing some 7070 emitters rated at 6V 5A. So yes, 30W per emitter. There are some which are 15W, 18W though.
Some folks here might even be able to swap those chinese 7070s out with their spare XHP70s within 10 mins or so, don’t even need to change the drivers if they are driving the LEDs decently hard, meaning that with XHP70s the light would be putting out more light while running cooler. The possibilities……
Then next week after the holidays i might try to get it for under rmb 300. Maybe tomorrow even (most of them are already working esp on TB), counting on you Sillen!
I like this little corner on the benchtop ’cause it’s all white’ish. I put Samsung S7 between the bowl and the lux meter sensor. S7 using Lux Meter app.
Results are:
D4S XPL HI 680
ROT66 Nichia came with VCT6 from Neal (blinks 4V) 1070
BLF Q8 VCT6 from Oz (Blinks 3.8V) 1200
Sofirn Q8 VCT6 from Oz (Blinks 3.8V) 900
S41 Nichia 250 Rome Q30 Banggood supplied 30Q’s (Measured 4V) 1400
S70S 800
BLF A6 260
Not at the price that i am shooting for at about rmb 300 (43usd or below). It would be a practical budgetlight league for sure. There is also a practical side of things as i do not like to use my expensive stuffs out there for “trashing”.
The efficiency with gunning a single XHP70.2 to 7k lumens is already gonna be…… :weary: Gonna gain throw of course.
The UI is not too bad, of course it’s not like the BLF Q8. There is not too much duplication to the Q8 in real world apps also as this would be quite a fair bit floodier.
The other one that i am shooting for is Nightwatch NA40, about usd 39. 6000 lumens 3 x SST-40. Another budgetlight that i can really use outside + fit into the pant pockets even more easily, and uses 1 x 26650 so i don’t have to get another set of 4 x 18650($$:money_mouth_face: for it.
That’s charging 15 cells all at once. Was too lazy last night. Sad thing is I can charge that many at once even without breaking out the Lii402. What have I become!
Might try out the dedicated lux meter too. It was pretty close to the s7 sub 1000lux but over 1000 lux it started showing much higher readings
3 x XHP 35 HI swap? Haikelite MT09R 3 x XHP 35 but with more throw? Haikelite MT07S 1 x XHP70.2 netural white but with more throw and possibly more lumens?
Economical enough too as long as the light’s base price is low enough. I am wondering if the focus is going to be ok, anybody has come across similar mods? (single or multi emitter)
Thermals need to be perfect though, maybe need a sand-down of the host-emitter surface and using all the known tricks. I think this light stock is gunning ~ 20W to each emitter, thus gonna be overdriving the XHP35 HI decently on the stock driver, which is of course what we want.
Anyway, for single XHP70.2 generally available lights, the Haikelite MT07S gets 4500 lumens in neutral white (usd 52 lowest price that i could get). The Acebeam K60 thrower (88mm head anyway) is 5000 lumens in CW.
Not apple-to-apple comparios, but just for ref.
