Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
1270 posts / 0 new
Brett
Brett's picture
 What is the Constant Output of Amps needed from the batterys to run this Sofirn Q8 does anyone know ??
Brett
JasonWW
JasonWW's picture
Last seen: 1 hour 47 min ago
It does not work like that.
Any unprotected 18650 should be fine.
Are you asking what battery gives the highest output?
How many batteries do you plan to use?
The usual suggestion is 4 × 30Q button top. High drains give the best output.
If you don’t care about highest output, you can run high capacity like 3500mah as well as protected cells.
Brett
Brett's picture
@ JasonWW,  My self, im fine as i have a couple hundred 18650s to choose from VTC6,30Qs even some that put out a constant 35amps continuous unprotected, protected etc "but" my brother in Western Australia only has 18650s that he has taken out of old laptop battery packs & there flat tops,so he will have to solder blobs on the + end, Thats why i was wundering (to get full output) does he need 20 amp continuous from 30Qs or will protected 10 amps continuous do the job ? or would he be still getting full output with the old laptop batteries he takes out of laptop battery packs ??
Thanks...
Brett
JasonWW
JasonWW's picture
Brett wrote:
@ JasonWW,  My self, im fine as i have a couple hundred 18650s to choose from VTC6,30Qs even some that put out a constant 35amps continuous unprotected, protected etc “but” my brother in Western Australia only has 18650s that he has taken out of old laptop battery packs & there flat tops,so he will have to solder blobs on the + end, Thats why i was wundering (to get full output) does he need 20 amp continuous from 30Qs or will protected 10 amps continuous do the job ? or would he be still getting full output with the old laptop batteries he takes out of laptop battery packs ??
Thanks…
Mismatched cells are safe to use due to them being in parallel, but it’s best to use a matched set.
With 4 batteries the most it should draw is maybe 16A so that is only 4A per battery.
You will never get the highest output using old laptop cells. You need high drain cells with the lowest resistance in order to get the highest output.
Brett
Brett's picture
JasonWW,
Thanks Jason that makes perfect sense,i just told him on phone what you said & now i'll send him the banggood link to the samsung 30q batteries.
thanks again.
Brett
JasonWW
JasonWW's picture
Right now 4 × 30Q button top batteries are on sale for $20. Not bad at all. I might grab an extra set for myself.
Brett
Brett's picture
@ JasonWW,
 Yea maybe $20 USD for you for 4 x 30Qs on sale, "But" for me $28.20 Australian for 4 x 30Qs, A fair while back they were only $23 for 4 of them & so i bought about 32 of them & haven't seen them as cheep again since.  <img src= " /> <img src= " />
Brett
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 1 month 1 week ago
For us(we) Amazon US purchasers, I see only two reviews.  I know we all said thank you but I think Sofirn was hoping for a whole bunch of verified purchase reviews.  I wrote one of them.  I suppose anyone who received one is having fun all night (thanks to the high capacity) and sleeping all day!  tongue-out
EDC
FW3A, SST20 4000K || S21A, Crescendo MTNdd 20mm, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/6A 20mm SST40 driver, XP-L HI | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
Newlumen
Newlumen's picture
Last seen: 2 months 5 days ago
I will write reviews today.
Newlumen
Newlumen's picture
Just summit 5 stars review on amazon.
DB Custom
DB Custom's picture
Last seen: 1 day 7 hours ago
I sound like a broken record, but 5775.3 lumens is what I get once again on a brand new just took it out of mailbox Sofirn Q8. Rested 30Q cells at 4.19V. Literally dropped in the cells and put it on the light box, first time I turned it on.
Brett
Brett's picture
Hmmmm... Nice!  cool
Brett
DB Custom
DB Custom's picture
TK? I flashed Anduril on this new Q8 with the exact same result, no side switch back-light. Zero modification to the light other than flashing Anduril. And to be sure my file was clean I downloaded it fresh from your site and installed this new file. Under lockout condition, tap-tap-hold only gives me momentary moon level. No blinks or anything else. Testing functions shows Anduril working perfectly, as before.
DB Custom
DB Custom's picture
Maybe y’all can help me on this, I will be modifying this second Q8 soon and the plan was to use SST-40’s for something in the range of 10,200 lumens. (Done it before) But I like doing things different, so now I am wondering if it would be worth it to use XHP-50.2’s and see if I can get 16,000 or more from this Q8. Am even entertaining the thought of building a top end extension fitted down into the Q8 head with cooling fins above the existing head to aid in heat management. Probably wider than the stock head at these new fins. Thinking to just use 4 pairs of 18350’s, run time would suck but it wouldn’t be used for long periods anyway… I already have the new MCPCB’s, SST-40’s are en-route, don’t have the 50.2’s. What say ye?
teacher
teacher's picture
Last seen: 10 months 1 day ago
Go for broke, get the most out of it you can. Wink
BlueSwordM
BlueSwordM's picture
Last seen: 5 hours 20 min ago
I would say just wait for the extension tube for the Q8.
You’ll get 8×18650 compatibility and the ability to draw massive power levels. And much higher capacities compared to 8×18350s.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 9 min ago
…….. POOF! Big Smile
KB1428 “Live Life WOT
DB Custom
DB Custom's picture
Kawi , I had three in my scratch build that drew 21A at 13,000+ lumens, no poof!
The one in my Jaxman is making 3000 plus on two 14500’s. Think it’s at 3A or so in that light.
Djozz has tested them up to 15A.
But yeah, there’s that possibility which is why I asked. The Quad set up may make the difference, don’t know…
DB Custom
DB Custom's picture
Either way though Kawi, I’ll have 4 more HI’s you can have… Wink
pennzy
pennzy's picture
Last seen: 2 hours 22 min ago
The Q8 ramping mode blinky settings has me confused. Double click to turbo, double click to strobe…then what ? I have tried single, double, and long presses and I can get it to change strobe types sometimes but not with any consistency, Also , it doesn’t memorize the change for next time. Should it remember the new strobe setting?
Nachtfeuerzeug
I don't think so. You do have to keep on clicking till you get to the Blinky you want.
EDC
Reviews:
FritzHID
FritzHID's picture
Last seen: 5 months 4 weeks ago
you can’t dilly dally when in strobe, as soon as you enter it, you need to click to the strobe mode you want, single clicks, within 1 second or that mode will lock in….
unless you got a defective light but i have never heard that particular issue.
& no, it doesn’t save strobe settings.
pennzy
pennzy's picture
Hard to tell which strobe mode you have switched to if you have to click within 1 second in order to keep switching.
teacher
teacher's picture
Yep, it is. Thumbs Up . . To eliminate this problem just memorize/remember the number of clicks it takes to go to the strobe you want. That way you do not have to ‘see’ it to get there.
pennzy
pennzy's picture
Good tip, thanks.
teacher
teacher's picture
My pleasure…. I learned it the hard way. . Big Smile . . Wink
JasonWW
JasonWW's picture
Just click to any blinky mode besides the first one.
It will lock in after 1.2 seconds. Press and hold and it will go back one blinky mode and unlock for 1.2 seconds, at which point you can go forward through all the modes. If you stop on the wrong one, press and hold to unlock again.
This is the same procedure for mode sets.
Blinky modes are not memorized.
Try this video, it’s not very good, but it shows the basics.
https://youtu.be/rdwah7HJAJA
teacher
teacher's picture
/\ ….. Thanks for that info Jason. . Thumbs Up . I didn’t realize that could be done. Of course I rarely use blinkies….. Wink
I have number of clicks to ‘beacon’ memorized & that’s it for me. Big Smile
pennzy
pennzy's picture
I watched all your videos , Jason. They were very helpful.. I don’t use strobe much but I was just monkeying around with it and wanted to learn it. Thanks.
d_t_a
Last seen: 5 hours 19 min ago
I got my Sofirn Q8 from AliExpress. It came with NarsilM v1.0, I have flashed it to Anduril (09-07-2018 hex).
My side switch button does light up, and can be configured to Off, Low, High or Blinking states.
I’m not sure I understand what you mean by no side-switch back-light? The side button totally does not light up green?
