Low-cost copper pills, spacers, optics, drop-ins. Custom parts.
1780 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 2 hours 37 min ago
kiriba-ru wrote:
If somebody will be able to supply 17mm boost drivers, I would make S2+ pills for single led.
∅20mm H1-A driver can be used soldering it to the pill with a hot air gun. H1-As maximum Vout can be modded for triples, see Jensen567's work.
Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Barkuti
Barkuti's picture
This is a little job I've done with a genuine UltraFire SK98 flashlight's pill.
Inner cylinder is ∅11.1mm approximately, made of two 1mm thick copper discs. Under it is soldered to a ∅18mm 1mm thick disc, and thermal glued to the pill's balcony.
This model would thank a nice and beefy copper pill, it is very easy to mount an H1-A driver in, fits snugly.
Originally posted on Sun, 07/29/2018 - 19:38. Added comments. Further edit to remove wrong white balance pics.
hanson405
Last seen: 1 year 3 months ago
MascaratumB wrote:
Those would run XHP Leds? I would buy driver and pill Evil
mtnelectronics is supposed to have something in the works, available at the beginning of August! I suspect a copper pill will be quite necessary when running an XHP in an S2+
MascaratumB
MascaratumB's picture
Last seen: 12 min 56 sec ago
Thanks for the info mate! I’ve been reading RMM’s thread and noticed that recently Wink
I’ll be looking for it on both thread and in MTN site! Thanks for sharing Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
skinny_tie
skinny_tie's picture
Last seen: 14 hours 48 min ago
kiriba-ru wrote:
$10 Last time I had them was more than a year ago. Dont remember weight. Defenetly under 50gr.
Thanks kiriba-ru. Could you please put me down for two B158 pills?
kiriba-ru
kiriba-ru's picture
Last seen: 16 hours 54 min ago
Wieselflinkpro wrote:
kiriba-ru wrote:
$25, copper
Ok, I let my custom aluminium Pill inside.
Im sorry, it requires as much as 20x S2+ spacers in material and as much as 10x S2+ spacers machining time.
Money is not target, I left the message to finish as much custom (small quantity) orders as it is possible ATM.
If you think parts are overprices, you are welcome, just $10 for any die (I will help with tips and drawings), it would be great if another BLF member would provide this pills could keep prices at better level.
Wieselflinkpro
Wieselflinkpro's picture
kiriba-ru wrote:
$25, copper
I do not have a the possibility to make something like this and I do not say, it is overpriced. But its not worth for me for this flashligt.
Lightbringer
Lightbringer's picture
Last seen: 20 min 37 sec ago
Got my goodies, tnx!
Now I’ll see what a triple of 351Ds will look like… Big Smile
g_damian
g_damian's picture
Last seen: 2 hours 42 min ago
Hi, I’d like to order
  • Carclo 10622 24mm quad Narrow Spot Plain TIR (for M2, P60, U11 quads) – $1.5 in stock
  • Copper spacer+brass centering ring set for quad mod Convoy M2 – $10, 55g
Thanks!
McLight
McLight's picture
Last seen: 6 months 1 week ago
Location: German rain does not fall, our rain occupying the area.
I got my S2+ Parts today, great packed & shrouded with wrapper.. And Postman rings for it.. 9 days to germany.. Great Job.. Crown
Thank you kiriba-ru
In GoD & Trance we trust, the rest pay Cash!!
g_damian
g_damian's picture
New build today: Convoy M2 quad with Optisolis 4000K. Thanks kiriba-ru for your excellent parts Smile
MikeMacD
Last seen: 3 weeks 4 days ago
I received my copper S2+ spacers in less than 2 weeks to the US! Packaging was excellent! Thanks!
shirnask
shirnask's picture
Last seen: 7 hours 6 min ago
I would like –
Copper pill triple Convoy S2+ (Convoy retaining ring)
Copper spacer for Carclo triple Convoy S2
Plaese PM me with details
Thank you
kiriba-ru
kiriba-ru's picture
All triple pills are gone. I think single led copper pill looks more interesting since 17mm boost driver is available, so single pill is next to be produced. I havent seen great demand for triple pills last time, not sure I should make more of them. Please leave your comment if you dont agree.
kiriba-ru
kiriba-ru's picture
One more price drop for many items related with ruble devaluation.
rub
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 3 weeks 3 days ago
Hello,
will P60 Surefire copper quad shelf find into the this host ?
P60 head size
inner head tube 22mm
max inner diameter 24,5mm
lenght from bottom head to glass 33mm
(from screws – there is no shelf, a spring is hold by battery tube)
Brass Pill + reflector size that fits to host
lenght pill + reflector (wo spring) 27,5mm
max reflector diameter 26mm
Body reflector diameter 21,75mm
kiriba-ru
kiriba-ru's picture
Could you please show the top of the head?
F.i.l.a.s
F.i.l.a.s's picture
Please see,
kiriba-ru
kiriba-ru's picture
I dont see any reason why quad drop-in wont fit.
But I think this surface on top of the head is the only reasonable pad to transfer negative to the pill. If you can sand the ano down to the bare aluminium, it should work well.
SKV89
Last seen: 6 hours 51 min ago
If you have anymore of the copper S2+ triples or make more, I will buy three. Thanks.
staticx57
Last seen: 5 hours 48 min ago
I was actually hopping to buy some S2+ triple pills as well
shirnask
shirnask's picture
I got my S2+ Parts today – FAST – Thank You
MikeMacD
Parts received! Great quality copper pills!
kiriba-ru
kiriba-ru's picture
Need a person who wants to make a belt grinder from an angle grinder. ASAP.
Skylight
Skylight's picture
Last seen: 5 hours 33 min ago
kiriba-ru, would it be possible to make a short 18350 tube for the Convoy C8? I can’t find one anywhere and I like short flashlight versions like the GT mini.
kiriba-ru
kiriba-ru's picture
Had few requests but defenetly not enough for cnc batch.
Skylight
Skylight's picture
Thank you, kiriba-ru! Looking forward to the day when Convoy will produce one.
kiriba-ru
kiriba-ru's picture
Up
id30209
id30209's picture
Last seen: 40 min 17 sec ago
Hi kiriba, I would need: 2 x P60 Surefire copper quad shelf (Convoy retaining ring), 22.00mm – $12 1 x Maglite D kit Aluminium drop-in+copper pill, fit 30mm driver – $12 1 x Driver brass adapter: 20/22mm press fit – $3 1× 17mm with retaining ring – $4/$7
Can you send PM with payment details please
WTB Titanium 4sevens 2xAA tube
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 3 weeks ago
kiriba-ru wrote:
Up
How much?
