Well i somewhat agree, since this kind of lights are so big they should make them a little bigger but improve the cooling capacity it would only make the lights of this size even better.
The MS12 has sidelights that are probably 20 lumens at their lowest setting and Turbo can run for over 5 minutes indoors!
I’ll probably wait for Imalent to hit 80k.
I have not heard anyone suggest that the handle was made out of plastic. Only the actual fan itself is made of plastic, everything else should be metal.
Imalent could decide to put also a fan in a handle, with better results than Acebeam,as the pumped air would blow direct onto the special cooling heatsink which there is in the head.
Oh i thought it was the other way around, that “thing” is gonna blow the hot air out… then it means hot air will blow in your face direction like a hair dryer ? hm…
well talk about clumsy light then, but if u want hold it normally then? the button is on the side the hot air is supposed to come out right or do they expect everyone to use the light by carry it like a suitcase seems weird to me.
Obviously the whole handle thing was a last minute redesign.
Remember that hot air does not come out of the light because it doesn’t appear to go into it. It just blows on one side of it. I doubt you will feel any hot air on your hand.
