On my second Sofirn Q8, I have replaced the tail pcb with a copper disc, soldered Blue’s heavy large springs directly onto this disc, put 20ga spring bypasses inside the springs. So now, on the same cells (fresh charge) it makes 6379.05 lumens, up from the stock 5775.3 lumens… a 603.75 lumens gain.
Each of the four XP-L HI’s is making 1594.76 lumens.
(The point I’m really trying to make here is that Sofirn built these lights quite well, very close to maximum performance right out of the box.)
On 2 18350 Vapecell’s they go poof…FETDD driver, never seen one make it past 11-12 amps myself…so I quit using the 8awg test loop and Amp meter to test…current pull. I had one 50.2 on 2 Efest 18350 I would charge to 4.0v but it went poof later on down the road…when I put 2 18350 Aspires in it… I forgot… :person_facepalming:
And my Sofirn Q8, with stock XP-L HI’s, is now making 6513.6 lumens.
This new 158.7 lumen gain simply by swapping in an incredibly clear UCL glass lens from flashlightlens.com. This is a 55mm x 1.9mm AR coated both sides glass lens with 99% transmission. The stock lens has no coatings and is 2.9mm thick, so I had to use a thicker clear o-ring, but other than that it was a straight swap. The UCLp in Acrylic can be had in 3mm thickness for a direct swap. I got one of those as well, put it in the light I have listed as an option in my giveaway, charging the Samsung 25S cells in that one to see what kind of final reading it has…
737 lumens gained by acute attention to the circuit’s ground and a lens swap. (replaced PCB with copper disc, Blue’s large springs, 20 ga bypasses, UCL AR coated lens)
Oh, I did 10,200 with SST-40’s quite a while back in the original Q8. Sold that one to Slow2Go earlier this year.
I want 15,000 or more now. Considering how to go about that. The power grid on this one I just got is ready to go, just have to figure out what I’m going to do up top and not spend a fortune doing it. I have some thick walled aluminum pipe here as well as some pure copper that is difficult to machine, may just make a copper core for the heavy pipe and then cut an extension with fins to be able to use 8 18350’s to power 4 XHP-70.2’s. That should be good for upwards of 20,000 lumens and maybe then some. Working on figuring it out, this method would enable me to use some components that have been sitting here gathering dust for a while…still would have to spend $100 on emitters and cells. That’s the yuck part.
