Ordered two SF13's on Sep-9 but still not here yet. Specs show 420lms which seems bright enough for that type of light. I got many lonely AA eneloops waiting to be used.
I heard the acebeam pt10 gets real hot. Did not arrive at my door yet, but for the money, I'm thinking sofirn's SF02 may be the best all around penlight for the money. I really like my thorfire pf04 but many have said Sofirns SF02 is brighter and for just $9.00 it may be my number one Christmas gift choice for friends and family.
Yeah, with new cells it’s pretty bright. Burns down alkies nicely, ’til it’s essentially a 1-mode light, then starts acting weird (flickering, slow-blink, etc.) which means it’s about time for real to ditch the cells. Then into Bobofett II they go.
I’m too busy burning down those alkies to try eneloops or the like.
Okay, not quite a penlight but is technically half of one. The Utorch UT01 puts out 800 lumen with a 14500 Li-Ion and 400+ from a AA.
Its steps are programmable, quality is good and it’s offered in both CW and NW tints. I have several and the quality is very good
Indeed, you are right. Glad someone is clever enough to point that out.
Fact is that I hate penlights. I associate them with white coats. At my age I have seen enough of them.
The idea that they make me live longer is incorrect. They take away so much fun that it just seems longer.
It’s just an inspection light, to look at things up close.
It makes a near perfect circle of uniform brightness.
Probably not usable for more than 5-10m but I like the host and might mod it in the future, or just use it as is since it has long battery life.
The i4 that I plan to buy soon is more modern, with 120 lumens max and a focusable beam, but also with a low mode for long runtime.
i4 may be good for me too. Never thought about anything with such a focused beam before but can see the benefits of something like that for detailed work.
It’s nice because you can get brighter flood or longer range than a similar lumen output flashlight, just not both at the same time.
You can think of it as having 240 lumens instead of 120, since a reflector 240 lumen flashlight would have both spot and flood at the same time.
I personally use the tight beam more for long range rather than detailed work.
The super uniform flood is better for up close.
