Interesting. The blue v2 is pictured with a SMO reflector, but the description says it has an OP reflector. The black is pictured with an OP reflector.
And now there is a $3-off coupon, which works out to $11.99.
I got my today (finally!).
I use only AA, so canāt comment on 14500, but starting with low (5lm) instead of eco (0.5lm) is a big disappointment. :person_facepalming:
One needs to click (slowly) 4 times to get to Eco mode. Unfortunately 4 quick continuous clicks turns flashlight to lock-out.
I have previous version as well and itās perfect EDC :heart_eyes: , as it starts - according to manual - with Moonlight (1lm) witch to me looks more like 0.5lm or even less.
Now Iām wondering who in my family or among my friends will be the victim and is going to get it from me as a gift. :innocent:
The ML is so low on mine I have to check if it is on or not . What do you use it for?
My wife appropriated it to use during the nights not to wake up our baby girl.
And you are right - during the day itās hard to tell if itās on or not
So I received v2.0 today. After one hour playing with it, the light fell on the ground - and was dead :person_facepalming:
One single ( and first one) fall on the ground! :rage: Unbelievableā¦
It looks like Sofirn did nothing with āImpact resistance issuesā Sofirn SP10B - Impact resistance issues?
Seems to be a pattern. Check your LED . Mine came off without dropping it . Good news, Sofirn stands behind their product. Give them a message.
https://s.click.aliexpress.com/e/tZGgdNO
Is this a pricing mistake or are they trying to get rid of the product? Seems lower than ever at $7.30 on sofirnās AliExpress store. I picked up a few but I havenāt been following the threads on this version so I hope thereās nothing wrong with theseā¦
8,21$ now.
I think you are right and they are getting rid of the V 2.0 batchā¦
V 2.0 is crapā¦ Lower output than v1( only about 170 lm with AA), the head is glued :person_facepalming: , and my copy died after single drop on the floorā¦
Ahh crapā¦didnāt know head was glued and doesnāt start on moonlight. Will try to cancelā¦
Yeah, I feel like the v2 is a big step backwards. The prior driver version had a better UI. Ideally theyād use it and just add another mode between moonlight and the old low.
Is it true that it doesnāt have memory mode for AA? Thatās a huge negative, if true.
Mode memory does not work when using NiHM (and other AA cells)? Is that right?
Can someone please confirm that!
Thank you.
Thatās correct. No memory and moonlight is the last mode accessed. Those two things kill this light for me. I really never use it.
I got one of these, and it just doesnāt feel substantial. So lightweight and cheap feeling. Unimpressive.
Thanks for the comments!
I was seriously considering buying this light (I like the lights size and style), but lack of mode memory, and questionable reliability (when dropped or hit heavily?) has changed my intentions. Definitely will not get this light.
Itās crazy how so many expect a high end flashlight and pay so little. If you want something built incredibly well then pay more!
I have since changed my tune about memory mode. Itās perfect for lights that have shortcuts to moonlight and turbo and it helps āfixā wonky UIs like Tool AAās default medium, otherwise itās almost as annoying as NMM and I never use it.
This has a feature to hide high mode if the battery is almost dead but moonlight gets hidden as well because comes right after high mode. I canāt wait for the Anduril version.
