The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
There’s no way to access 80? I thought someone said we can go to turbo and ramp down to get to the levels between 60–100%.
That might be for Anduril, Narsil does not support this at this time.
It was a debate but in the end it was decided that having the ramp stop at a level that was safe for long term use and basically “muggle proof” was the best overall option and I agreed with that.
Plus it makes turbo look more impressive.
In Andúril you can set the ramp max where you want. If you need ramp from moon to turbo you can set it. But if you set ramp max to 60% you can’t reach 80% any way. Just if you set ramp max to another level in ramp cfg.
So anduril does not have a turbo option to go to 100% with a double click?
Huh?
Why do you think this?
It should the same as NarsilM. You dbl clk for turbo.
It has double click turbo. But it is only works when the light is on. from off with a double click you jump to ramp max.
Ah, ok I get it now, that is pretty nice. What happens when you ramp down from 100% turbo with the ramp max set at say 50%?
First it jumps down to 50% and if you keep holding it ramping down to moon. You also can set moon level anywhere you want.
I made a complete Anduril UI setup and how to video:
Thanks TA! I am very happy with top of ramp around 50-60% for the reliability factor you mentioned.
I thought that coming out of turbo would put you back to the top of the ramp again. However, that is not the case on my CW version. Top of ramp is a higher level than the first level coming out of turbo. (Didn’t test on NW version yet)
It’s not an issue, I was just curious about that level and if others have noticed this too.
Great explanation and visuals on the differences between Narsil & Anduril above. I am super happy with Narsil as is. Will have to flash and play with Anduril one day soon too. Thanks to BLF, it seems flashing the MCU can be accomplished by almost anyone willing to read and learn the procedure.
Zozz, you didn’t say you reflashed the driver on that D4S. People might get confused.
Thanks for the heads up!
I written it in the video description now.
Interesting, so it does work just like Narsil in that sense.
Strange that it is not dropping to the top of the ramp on yours, I tested it on my light and that is how it works.
Now it does start ramping instantly, so most likely you will ramp down a little before you release the button thus giving you a slightly lower level.
Thanks TA. It still seems like it steps down further for me but as you said, I’m likely holding the button for too long.
Thanks again for the info on this and looking forward to the next new project from you.
GT70 = IMPRESSIVE
My GT70 arrived today. Tracking says it left China on the 3rd, China time, and got to PA on the 4th, east coast time. That was even with an error on the shipping label. Way to go DHL.
Fantastic light. The construction looks to be flawless. The light output both in lumens and profile is far better than expected. As Texas Ace has been saying all along, it is much more useful in real life situations than the original BLF-GT. It will definitely get more use than the original but both lights have their own uses that they excel at. I can't wait to have a longer time to play with this Giggle Monster.
Many thanks to all those involved in producing this and in pushing for the 70.2 version.
Yea… blf gt xhp35 is not a big deal any more when you turn on the gt70… so much light… i still like my xhp35 version for the xtreme throw…
Am I wrong, or couldn’t you dedome the xhp70.2 and get slightly more throw than the OG GT? As well as more otf lumens than the OG GT? Kind of the best of both worlds? I think this is my plan.
You could try it… all the people i talked to tell me xhp70.2 dedome give horrible green tint…
My BLF GT arrived today but it was damaged in a way that I cant use it. Should I PM the OP?
Wow, that is really odd for a DHL box. You would need to contact Leo or Neal next week when they get back to work from the holidays.
