Yesterday I received my Q8. I love that light and only complain I have is that I can’t unscrew steel bezel and tail cap. While I don’t care about the tail cap, I want to change the LEDs at some point.
Luckily this didn’t stopped me from flashing Anduril firmware on it. This is my first light with Anduril and I really like it. Everything seems to work fine, even switch light. Except battery indicator which isn’t accurate. When I put batteries which currently provide 3.8V and check battery voltage from Q8, the light blinks 4 times for 4.0 volts. Did I messed something when flashed it?
I used ToyKeeper’s hex from 09/30.
Modded my second Q8 again, this time with an emitter swap using LED4Power’s dual footprint boards. With sliced SST-40’s on it and the openings in the reflector reamed out so the reflector sits down onto the board, it makes 8349 lumens on the 30Q’s. The lowest level is 0.1035 lumens. Forward Voltage is low enough that Candlelight in Anduril isn’t smooth all the way down at the base level, but works fine with a tiny bump up.
The sliced SST-40’s make 8763 lumens with Samsung 25S cells in the Q8.
Edit: slicing them warms them slightly but they’re still on the cool white side. Lux is 116.75Kcd for 683.37M throw. Not bad at all for a nearly 9,000 lumen soup can light!
It’s not super accurate, but it should be good enough to tell you your batteries condition.
For instance the light may flash 4.0 when the battery is in a range of 3.98 to 4.08 or maybe 3.93 to 4.03. It tries to be close, but it can’t be perfect.
If it blinks 4.4 on freshly charged batteries then you have to mentally remember it’s .2 high.
If your flashing your own UI, maybe ToyKeeper can suggest an edit in the code to make your light be closer to accurate.
TK does indeed have a set that can be flashed into the MCU and measurements taken with different voltages of cells, this will flash out the code you need to put in the program to make your specific light more accurate. I don’t use it, She uses it for every build.
Way to go Dale! And excellent choice in emitters. I haven’t kept up with this thread, but my sofirn q8 arrived today and it’s one of my fav stock light under $40. Throws quite far and very bright. The funny thing is, I wanted to see if I can find if anyone posted stock lux numbers and I was browsing this thread and saw your post asking what we think between xhp50 or sst40?
I was gonna reply back after I finish with reading this thread, that I would personally opt for shaved sst40 for throw and high lumens.
Regular sst40 and xhp50 will give lots of lumens but there are lots of soda can lights that can already do this with even more lumens.
But not many or none out there with decent high lumens and throw.
Though I already had emptied my cart, a few days ago I got a message in my mail to “confirm but not pay” my order of the Q8. So I put the Q8 back into the cart and tried to do what they asked. This was the first time to opt for this procedure. At first the suggestions in this forum did not quite look fitting my case, but eventually I managed to get into the next level (we are awaiting your payment). Yesterday I got a noticication in my mail that the price was adjusted!! From then on it went smoothly. So I will be waiting for the postman too.
My late mother always said: I’ll be the first to admit when I’m wrong, but this time I’m right (as always).
Well now it is my turn. I should have listened better to myself, when telling others that you need to have patience in doing business with Chinese sellers (holidays, time-zones, deadlines, etc). In this case I did not have enough patience. I am glad Sofirn did. Thank you, Sofirn.
