Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
1280 posts / 0 new
klrman
klrman's picture
Last seen: 5 days 15 hours ago
DB Custom wrote:
klrman, it probably should be. More than a little scary, I have to admit. shirnask, I can't say if I've had that EXACT expression, but I know there's been more than a few times it had to have been pretty close to that. lol I found that pic when ToyKeeper started calling me Dr. Frankendale... :FACEPALM:
Haha.  I can only dream about modding like you do.  Right now, the biggest thing I've done is solder a replacement driver in my L6, but this Winter I will be reading many posts and will finally start to build something nice for myself.  I have to start small and build on it all.
pennzy
pennzy's picture
Last seen: 7 hours 40 min ago
I saw some Q8s on Ebay for about $40.
https://www.ebay.com/itm/BLF-Q8-5000LM-Super-Bright-4xLED-Tactical-Flash...
I know nothing about the seller.
Edit : I just noticed $10 shipping . Never mind.
nvanlaar
nvanlaar's picture
Last seen: 1 week 11 hours ago
JasonWW wrote:
nvanlaar wrote:
I was told the deal was good until the end of October… maybe they just meant the code was good until then… Facepalm
I assumed the Group Buy ended Sept 21 when Sofirn said it was ending that day. Sorry.
It was a PM reply to the code PM. I asked how long it would be good for (I had to wait until my next paycheck…). Was told End of October. The code still works, but the priced jumped by $20. Doh! ah well, can win em all I guess.
“Facts don’t care about your feelings.”
~Ben Shapiro
pennzy
pennzy's picture
Did you use the code ? The code was for $39.95 , regardless of what the list price is . Try it, maybe still is $39.95.
nvanlaar
nvanlaar's picture
I did. Nopers…
~Ben Shapiro
pennzy
pennzy's picture
Oh well, that sucks. If you are patient, sales will probably crop up. My first Q8 was $46.
teacher
teacher's picture
I am loving this Sofirn Q8!! I like the tint even better than the BLF Q8.
The fit & finish are about as close to perfect as it can be.
Thanks Sofirn…. Great job!!
Sillen
Sillen's picture
Last seen: 23 min 37 sec ago
nvanlaar wrote:
I did. Nopers…
![img]https://i.imgur.com/XmbuOAcl.png[/img]!
Bugger! I paid full price for my BLF Q8 off Amazon AU, AUD$78 when there was discount available to make it AUD$40 Sad
JasonWW
JasonWW's picture
Last seen: 37 min 37 sec ago
Sillen wrote:
nvanlaar wrote:
I did. Nopers…
First, it was for the Sofirn Q8 and secondly it was $40 US. The Australian conversion rate would make the price higher than $40 maybe like $56AUD.
$40 AUD is like $29 USD and they have never been that cheap.
I think there are coupons for the BLF Q8 for $46 USD, but not any for the Sofirn Q8 right now. Maybe soon though it will be available with a coupon.
Sillen
Sillen's picture
JasonWW wrote:
Sillen wrote:
nvanlaar wrote:
I did. Nopers…
I know it was the Sofirn, I was sympathizing with the experience of paying more when less had been possible.
Yes AUD$40 is like USD$29 and it was that cheap. It was a mistake but orders were filled https://www.ozbargain.com.au/node/392606
jigsaw
jigsaw's picture
Last seen: 3 weeks 3 days ago
Is there a decent diffuser available for the Q8?
ohbreeeezy
ohbreeeezy's picture
Last seen: 3 days 2 hours ago
gkushev
Last seen: 2 hours 5 min ago
Yesterday I received my Q8. I love that light and only complain I have is that I can’t unscrew steel bezel and tail cap. While I don’t care about the tail cap, I want to change the LEDs at some point.
Luckily this didn’t stopped me from flashing Anduril firmware on it. This is my first light with Anduril and I really like it. Everything seems to work fine, even switch light. Except battery indicator which isn’t accurate. When I put batteries which currently provide 3.8V and check battery voltage from Q8, the light blinks 4 times for 4.0 volts. Did I messed something when flashed it?
I used ToyKeeper’s hex from 09/30.
contactcr
Last seen: 6 hours 5 min ago
I just checked mine and it isnt glued. Just use the bottom of a mouse pad/shoe/carpet. Twist and press at the same time and it will come off easily.
jigsaw
jigsaw's picture
Mine is stock. Battery meter seems to read slightly high also.
gkushev
Thanks for the reply, I mange to unscrew the bezel :). But wasn’t easy for sure, Maybe I should grease the threads.
DB Custom
DB Custom's picture
Last seen: 3 weeks 6 days ago
Modded my second Q8 again, this time with an emitter swap using LED4Power’s dual footprint boards. With sliced SST-40’s on it and the openings in the reflector reamed out so the reflector sits down onto the board, it makes 8349 lumens on the 30Q’s. The lowest level is 0.1035 lumens. Forward Voltage is low enough that Candlelight in Anduril isn’t smooth all the way down at the base level, but works fine with a tiny bump up.
djozz
djozz's picture
Last seen: 1 hour 5 min ago
Those SST-40’s look cool in there!
Dirt
Last seen: 1 week 4 days ago
This iteration of my favorite light has some serious down range punch.
Not a cool white fan usually, I like this one.
DB Custom
DB Custom's picture
The sliced SST-40’s make 8763 lumens with Samsung 25S cells in the Q8. Wink
Edit: slicing them warms them slightly but they’re still on the cool white side. Lux is 116.75Kcd for 683.37M throw. Not bad at all for a nearly 9,000 lumen soup can light! Big Smile
klrman
klrman's picture
gkushev wrote:
Yesterday I received my Q8. I love that light and only complain I have is that I can't unscrew steel bezel and tail cap. While I don't care about the tail cap, I want to change the LEDs at some point. Luckily this didn't stopped me from flashing Anduril firmware on it. This is my first light with Anduril and I really like it. Everything seems to work fine, even switch light. Except battery indicator which isn't accurate. When I put batteries which currently provide 3.8V and check battery voltage from Q8, the light blinks 4 times for 4.0 volts. Did I messed something when flashed it? I used ToyKeeper's hex from 09/30.
My stock Q8 reads .1v lower than actual voltage.
JasonWW
JasonWW's picture
klrman wrote:
gkushev wrote:
Luckily this didn’t stopped me from flashing Anduril firmware on it. Everything seems to work fine, even switch light. Except battery indicator which isn’t accurate. When I put batteries which currently provide 3.8V and check battery voltage from Q8, the light blinks 4 times for 4.0 volts. Did I messed something when flashed it? I used ToyKeeper’s hex from 09/30.
It’s not super accurate, but it should be good enough to tell you your batteries condition.
For instance the light may flash 4.0 when the battery is in a range of 3.98 to 4.08 or maybe 3.93 to 4.03. It tries to be close, but it can’t be perfect.
If it blinks 4.4 on freshly charged batteries then you have to mentally remember it’s .2 high.
If your flashing your own UI, maybe ToyKeeper can suggest an edit in the code to make your light be closer to accurate.
DB Custom
DB Custom's picture
TK does indeed have a set that can be flashed into the MCU and measurements taken with different voltages of cells, this will flash out the code you need to put in the program to make your specific light more accurate. I don’t use it, She uses it for every build.
joechina
Last seen: 6 days 23 hours ago
I didn’t read the whole thread, but shouldn’t Sofirn use NarsilM v1.2 in the Sofirn Q8?
JasonWW
JasonWW's picture
No, it’s using the same version as always for the last year. Maybe they will switch to a newer version later on.
klrman
klrman's picture
JasonWW wrote:
klrman wrote:
gkushev wrote:
Luckily this didn't stopped me from flashing Anduril firmware on it. Everything seems to work fine, even switch light. Except battery indicator which isn't accurate. When I put batteries which currently provide 3.8V and check battery voltage from Q8, the light blinks 4 times for 4.0 volts. Did I messed something when flashed it? I used ToyKeeper's hex from 09/30.
It's not super accurate, but it should be good enough to tell you your batteries condition. For instance the light may flash 4.0 when the battery is in a range of 3.98 to 4.08 or maybe 3.93 to 4.03. It tries to be close, but it can't be perfect. If it blinks 4.4 on freshly charged batteries then you have to mentally remember it's .2 high. If your flashing your own UI, maybe ToyKeeper can suggest an edit in the code to make your light be closer to accurate.
In my case I like the way it reads my batteries.  If cells are 3.7v actual, my Q8 will say 3.6v.  Keeps me ahead of the game a little.
blueb8llz
Last seen: 4 hours 55 min ago
Way to go Dale! And excellent choice in emitters. I haven’t kept up with this thread, but my sofirn q8 arrived today and it’s one of my fav stock light under $40. Throws quite far and very bright. The funny thing is, I wanted to see if I can find if anyone posted stock lux numbers and I was browsing this thread and saw your post asking what we think between xhp50 or sst40?
I was gonna reply back after I finish with reading this thread, that I would personally opt for shaved sst40 for throw and high lumens.
Regular sst40 and xhp50 will give lots of lumens but there are lots of soda can lights that can already do this with even more lumens.
But not many or none out there with decent high lumens and throw.
Henk4U2
Henk4U2's picture
Last seen: 45 min 1 sec ago
Henk4U2 wrote:
JasonWW wrote:
Henk4U2 wrote:
Tried to order on AE. First with request to adjust price in message field in my cart.
Later same question to Sofirn in the message center in “my” AE.
Same response: none whatsoever. Well: two can sing that song. Consider me out of this buy
Maybe I just got stuck between two bits in their answering bot. IDK, but I’m done with Sofirn.
So you ordered from AE back when the group buy was still active, but they never adjusted the price for you?
They didn’t. But never mind. I will find myself another light for my four spare 30Q batteries.
Already un-subscribed the thread.
Though I already had emptied my cart, a few days ago I got a message in my mail to “confirm but not pay” my order of the Q8. So I put the Q8 back into the cart and tried to do what they asked. This was the first time to opt for this procedure. At first the suggestions in this forum did not quite look fitting my case, but eventually I managed to get into the next level (we are awaiting your payment). Yesterday I got a noticication in my mail that the price was adjusted!! From then on it went smoothly. So I will be waiting for the postman too.
My late mother always said: I’ll be the first to admit when I’m wrong, but this time I’m right (as always).
Well now it is my turn. I should have listened better to myself, when telling others that you need to have patience in doing business with Chinese sellers (holidays, time-zones, deadlines, etc). In this case I did not have enough patience. I am glad Sofirn did. Thank you, Sofirn.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
DB Custom
DB Custom's picture
A short video of the Sofirn Q8 Quad in action with sliced SST-40’s…
FritzHID
FritzHID's picture
Last seen: 10 months 2 weeks ago
interesting…
My Sofirn Q8 flashed the low “batt signal” at 3.22v on my q35s tonight… at about 1/3 power…. Sad
yeah, not well calibrated. did a full shutdown at 3.13v.
this is an issue. !!!
