Itās better than the majority of 18350 out there but too bad not as good as the Aspire and Vapcell. Iām really looking forward to a 1500mah 18350 to match 18650 energy density. Thanks for the review!
The already known Yodeli 18350 1100mAh 15A (cough!) 10A cell. No surprises. It seems that Yodeli bins their cell production with slight chemistry changes and sets slightly different pricepoints to it, this is the reason this cell ranges from ā1000mAh to 1100+mAh:
The curve shape is a little bit different for the BestFire and Shockli cells. The Shockli performs a little bit better at high current, with slightly less capacity than its wrap figure. Overstated as they like to.
Cheers :-)
P.S.: the weight in the Shockli cell chart (20.7g) seems incorrect.
And, for a given generation of materials & chemistry, a larger cell will also have a lower IR and higher power density, because it will have ~two or more times the electrode area.
Or, putting it another way, if Samsung made an 18350 that was exactly the same as the 30Q, except the case and core were shortened. It would have <1500mAh capacity, and it would have a continuous discharge rate of <7.5A.
Did someone able to somehow properly test these bought some recently? I am wondering if the stuff is still at least as good or super close, I mean, if they haven't gone downhill too much.
Shockli 18350 1150mAh Battery have promotion on US Amazon
- Shockli 18350 1150mAh Battery specifications
- Capacity: 1050mAh-1150mAh
- Continuous / Max Discharge Current : 10A / 15A
- Work Voltage : 2.75V ā 4.2V
- Positive: Flat Top (Does not make contact if used end to end in series for flashlight)
Ideal for : Flashlight, Electronic products
Promotion on USA amazon store
You can searchā18350 batteryā in us amazon, USA BLF number can PM me on BLF or email to sales@shockli.com, I will give $3 promotion code, you can get 2pcs 18350 battery in $ 12.99, Now the promotion only available on us amazon
