On the 8th, it was shipped, and the appearance could not be changed. X70 is for the MS12 to work out, there will definitely be an upgraded version of the X70GT
translated his chinese…
so if im reading this right it means they have plans for an x70gt ? seems acebeam dont want imlent to be near their lights in terms of lumens lol…
I wonder if it's worth waiting for the x70gt? I would think that it would not only have more lumens, but maybe figure out any short comings that the x70 may have had.
Could be. Would be nice if acebeam also considered the many around here, including myself, to be decent enough to offer the X70GT with an option to "not" use a battery pack. I just hate battery packs and want to monitor all my own cells than trust a pack.
I remember reading they revised the X65 atleast once to fix some bugs and increase the output from the original. However, things like this is never guaranteed. Isn’t the X80GT, the only GT Acebeam ever did?
Acebeam posted these 2 pics on facebook its the highest mode according to them, kinda low quality not sure why they dont shine the lights at longer distances showing the lights true potential ?
no metal case? shame… those looked cool way better pics then posted on fb. really weird no steel bezel also should have kept that imo for that extra nicer looking touch, but im sure that light will be crazy fun on highest mode hehe.
Hard to see any difference between the ms12 and x70 actually its almost like the same light…
I personally don’t like heavy & bulky metal box; IMO, soft carry case is more pratical. I agree SS bezel looks much better. In 1st beamshot, X70 throw much better than MS12.
X70 beams are so even… no obvious darker spots.
That’s good charging implementation for battery pack. If one needs to unscrew battery pack to charge, why don’t let one use their own batteries. Imalent must be over thinking about waterproof.
Blowing air into flashlight is worse than across the outside.
The heatsink must act as highway for the heat to transfer out of MCPCB. This is conduction of heat transfer which is more efficient than convection. External fin need fan to do efficient convection transfer. Acebeam has nailed it.
Having cooling fins hang down from the led shelf and forcing air across it is absolutely superior to blowing it across the outside. I’m pretty sure they abandoned this idea and went with the much less efficient external cooling, but some people think they still may be forcing air through the light. I was hoping for confirmation one way or the other.
I meant the inside closer to led MCPCB shell needs thermal mass acting as sink for conduction of heat. Outside fins that connect to this thermal mass need convection of heat through moving air, so fan is useful here. It is less efficient to make many holes inside to let wind through because conduction is more efficient inside and close to MCPCB. Unless it is done to reduce weight, else i don’t see why Acebeam wants to make fins inside.
Wow the X70 throws farther and also more floody than the MS12 by a pretty good margin! I wonder if it’s because the flashlights were not aimed consistently. But if it is indeed a fair comparison, the X70 is much more powerful than the MS12. In some of those pics, it even throws almost as well as the R90C.
