Yes, around 5000K nw is an option
:+1: :+1:
:+1: :+1:
What will the recommended cell for use in this flashlight be? mAh and amps drawn? Interested, if I can find a good energy solution for it. Thanks for this project!
Wondering the same. Will the Samsung 50E 5000mah (Samsung 50E 21700 5000mAh 9.8A Battery) be enough?
Or will the Samsung 40T 4000mah (https://www.imrbatteries.com/samsung-40t-21700-4000mah-30a-battery/) be required for max brightness?
Interested.
Interested w/ Nichia
Interested.
Some specs pleeeeeeeeeeaese!
Count me interested please
Definitely interested
Interested
Interested
Just a quick update. I have Anduril working on the PL47, including both the front-facing aux LEDs and the switch LEDs. The two sets of LEDs are synchronized, except that it’s possible to put the switch LEDs in a “low” mode while the front-facing aux LEDs stay off entirely. Or, they can also be configured for off, high, or blinking.
It seems to work pretty well, but I discovered one downside which only affects people who want to reflash the firmware. With the aux LED board connected, it interferes with firmware flashing. I’m not sure why exactly, but on the prototype, it’s necessary to unsolder one of the aux LED board wires before flashing, then solder it back on again afterward.
Otherwise though, it acts like a normal aux LED board… with the bonus that it changes color when the battery is low.
That sounds great ToyKeeper!
With Anduril firmware set up by Toykeeper, why would anyone want to flash something else?
As long as one can swap emitters, this light sounds like a winner, can’t wait to get my hands on one.
interested!
Definitely interested!
Interested
A newer version of Anduril later on, of course.
also interested, im on the quest to buy anything that toykeeper works on!
Interested
