So your memory works as normal again?
I just added a 680 ohm resistor and measure 677 ohms from spring to body, but I still have next mode memory for some reason. ???
^ the other factor involved is the resistors inline with the leds in the tail, if they are too low, the influence on the driver is higher. I use at least a few kOhm. What are your values?
I happened to have bought 2 of these tail light kits from Gearbest (two blue leds), so I checked the uninstalled switch.
It looks like 330 ohm? That doesn’t seem right. 33 with 1 zero?
Yes, 2x 330 Ohm, 165 Ohm resultant resistance and that is very low, the leds are probably really bright?
I checked my X2R build and it has 3x 33 kOhm parallel, so 10 kOhm resultant resistance. My tail leds are green and still very bright. You may try a bit lower, say 10kOhm each, 5 kOhm resultant resistance.
I need some help with re-wiring a new driver to a side switch in a MF04.
Driver removed. Do I replace the 30 AWG wires with something bigger ?
Here is the original driver. It is marked for color wires.
Here is the new Driver.
Where do the side switch wires go ? I do not know.
I see no need to replace any wires.
Do you have a DMM or some type of meter? I would find out what the original wires did.
The black is ground so I guess it’s a common ground design. So black wire to the G.
Confirm the white is for the switch. If so, it should go to the S.
The new driver only has output for one switch led so you need to choose which color led you want to connect to the new driver.
Maybe red wire is for red led and green wire for green led? What kind of switch lights are on the MF04? Whichever LED you choose you can attach that to the L which should be the MCU controlled LED output or you could attach it to the LS which should be a steady output.
Thanks ” JasonWW ”
It has a Breathing Green side switch light and it turns red after batteries get low.
It has been modded for the MF04 and the 2 wires are for the water pump.
I could hook it up and check it with a dmm, but I don’t want to risk damaging it.
Guess I may need to PM Lexel for help. Just hoping this was standard flashlight lingo that us newbies don’t know.
Damaging it? You must not have understood me. Just check the switch wires for continuity. Put one probe on the black wire and one on the white wire and see if pressing the switch makes contact.
All these companies don’t have any wiring standard for switches. Some use a a common negative and some use a common positive. The switch itself is not polarity sensitive, but the LEDs are. You might also check that the red wire connects to the red LED and the green wire goes to the green LED. It’s definitely possible that the green wire controls the red LED and the red wire controls the green LED. I assume the two colors are on opposite sides of the switch. If you accidentally hook up the wrong color LED it’s fairly easy to go back in and switch it for the other wire.
The best thing to do is get a piece of paper or a notebook and write down the switch wires and what they go to and then draw a diagram so that you understand where everything goes and what it does.
Lexels connectors are fairly well known.
The S would be switch positive,
the G would be ground,
the L is swich led positive controlled by the MCU
and LS is switch LED positive constant on.
I have a solarforce L2T host sitting around collecting dust. Even if i get a dropin, it wont fet used much but at least it would be a back up or loaner. What is a good budget/value dropin module?
Thank You for the help “JasonWW”. I’m just a newbie here with the wiring.
I see people mentioning flipping a light; is that the same as flipping a house? Or is it some kind of mod?
House flipping is when a real estate investor buys houses and then sells them for a profit. In order for a house to be considered a flip, it must be bought with the intention of quickly reselling. The time between the purchase and the sale often ranges from a couple months up to a year. :question:
“Flipping” would generally imply selling for a profit (else why bother?).
For a light, you could buy a light, not like it too much (artifacts in the beam, green tint, lousy UI, etc.) and just sell it even for a small loss to someone who doesn’t know any better.
Dunno if that qualifies as “flipping”, but it’s almost the same thing, selling it to recoup some bux if you’re not gonna use it.
Can anyone tell me how to find common ground on a driver?
Yes, you need a multimeter of some sort. Put one probe on the outer edge of the driver which contacts the body and then use the other probe to poke around. Your looking for continuity.
If you give specifics, we can be more exact.
Why do people say “You cut yourself more with a dull knige compared to a sharp knife?
One downside to me finally learning how to sharpen my knives is... I have cut myself more often and much worse .
Lets dispell this myth
One downside to me finally learning how to sharpen my knives is… I have cut myself more often and much worse .
It has to do with the fact that you have to apply more pressure to the blade of a dull knife in order to cut something which can lead to the blade slipping and you accidentally cutting yourself. A really sharp knife requires very little pressure to cut something.
As Jason said, but I think it has two sides.
Yes you might ‘touch’ yourself with the blade more often and thus having the possibility to cut yourself.
But a dull knife won’t cut your skin as easy as a sharp knife.
So yes, with a dull knife you increase the possibility that the edge of the blade touches your skin when handling a knife.
But with a sharp knife you increase the possibility to cut yourself when the blade touches you.
First off, I don't use knives hard, and I'm pretty careful with them.
I have rarely cut myself with sharp knives.
I have never cut myself with dull knives.
I have done a lot of dry walling. Use a utility knife all day everyday. Cutting yourself does involve how much pressure applied but also presence of mind and a little luck. Knock on wood, never cut myself scoring drywall. Bought a knife once. First time I opened it I cut myself. Never liked that knife.
’Cause then you gotta press harder on the knife, risk having it slip, and cut your arm off at the elbow.
