They seem to work well. The moon is a bit brighter than most FET+1’s at about 5lm I think? guppydrv is nice but ill prob buy the next one with Bistro if it becomes available just to have a consistent UI. The host I used is a Jaxman mini C8 w/ 50.2 so turbo basically steps down instantly. The other modes look pretty consistent though.
Very much looking forward to higher powered 20-22mm versions.
I’m running one in both an m1 and a c8 with OP reflector. Each has a 50.2 in it.
I changed out the tailswitch springs on both lights with firmer ones, because a slight bump to the tail was enough to change modes on them. They have a brass button soldered on.
I am super happy with both lights. They drop down pretty quickly, but gradually when in turbo. You barely see it, but after 20-30 seconds it’s much less bright. They don’t get terribly hot though.
I think I got around 2200-2500lm between the two. Don’t have my notes handy. A bit more from the M1, as it’s a 5000k and the c8 is 4000k. Each was with a VTC5a.
Got a s3 host and a f13 ready to go as soon as the 17mm are back in stock and the 22s are listed.
If you have a way to measure the relative output can you try to disable the thermal protection on the C8 and see if it holds a steady turbo with a fully charged battery? I want to test this but i’m afraid to try it on my tiny host w/ just a pill. Doesn’t have to be long, as long as you feel comfortable just curious if turbo is ever constant.
I bumped mine up to like 185c and it still drops like a rock. Guess my host is not suited for this. I think my 50.2 4k 80cri peaks around 2050 lumens but only for a few seconds. Hoping your c8 soaks more heat and can be constant for longer. Maybe put it at 185 or 200c instead of disable at first
Looks like the C8 holding relatively steady turbo for 60-70s vs 10s shows that it is adjusting correctly. Now i’m curious if adding some type of heat sink to the coil on the underside would make any meaningful difference. Maybe no point testing such a thing until it bumps up to the 20-22mm size.
Would MTN Electronics ship small items with low value in an envelope to Europe? If you do not need many things the shipping costs more than the products themself!
Hi Richard,
As an aside, I’ve been one of your customers for awhile now and you folks have been great with reasonable prices and fast shipping.
I was wondering though when I ordered a couple of 26350 cells, one of them was leaking, (another gent here had a leaking cell also). I know you folks get super busy and I can appreciate that but I emailed you folks about it and received silence. You folks are usually very good at answering emails.
I didn’t ask for a refund or exchange, (I actually should have), but was just alerting you to the fact that your inventory of 26350 cells may contain some faulty examples.
Anyway and like I said, I’ve been very satisfied with many orders I’ve placed with you and just wanted to make you aware of this.
But then the team member outside the US needs to get a cut, right? I think as good as Richard is, people who are not in the US are just better off not buying from the US as long as our shipping is so high. Or at least, they should weigh for themselves whether it is worth a little extra cost to buy from Richard. Certainly, for some people, it is worth it.
Yes, it is definitely worth the cost even if shipping to Europe. I like the driver DIY kits and the pre-programmed MCUs. I just thought if envelope shipping inside the USA is possible it might be available also for Europe?! MTN Electronics does a good job shipping overseas. All the components are packed well and the items contained are all listed neatly on the outside of the package. It even arrives in less than a month. You just have to need more than only one driver so that the shipping cost is at least equal to the items cost.
There are unique parts not available or hard to get elsewhere.
There are flashlight shops which could just add Richard’s stuff to the inventory. That’s a small cost for them. I believe may be able to set up their cut in a way that makes such arrangement beneficial to all - themselves, RMM, non-US buyers.
