Interested
[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
Just a quick update. I have Anduril working on the PL47, including both the front-facing aux LEDs and the switch LEDs. The two sets of LEDs are synchronized, except that it’s possible to put the switch LEDs in a “low” mode while the front-facing aux LEDs stay off entirely. Or, they can also be configured for off, high, or blinking.
It seems to work pretty well, but I discovered one downside which only affects people who want to reflash the firmware. With the aux LED board connected, it interferes with firmware flashing. I’m not sure why exactly, but on the prototype, it’s necessary to unsolder one of the aux LED board wires before flashing, then solder it back on again afterward.
Otherwise though, it acts like a normal aux LED board… with the bonus that it changes color when the battery is low.
That sounds great ToyKeeper!
With Anduril firmware set up by Toykeeper, why would anyone want to flash something else?
As long as one can swap emitters, this light sounds like a winner, can’t wait to get my hands on one.
interested!
Definitely interested!
Interested
A newer version of Anduril later on, of course.
also interested, im on the quest to buy anything that toykeeper works on!
Interested
Before people get too excited, remember that it is first and foremost a 21700 right-angle light. If that is what you want, you’ll probably like it. But if you want a more traditional straight flashlight, a fancy interface won’t really help much. It’s kind of a specialized item.
The 219B emitters make a very nice pure-white high-CRI beam. And, though I may be a bit biased, I think it has a nice interface. But I use the ROT66 more because I like inline flashlights more than a right-angle lights.
Interested.
Interested
Great Advice regarding choice etc…
For me both inline and angled Flashlights have a place due to work and activity requirements……. So hopefully this may replace the Nitecore HC30 I have but that will depend on quite a few things once I have played with one…. Could be it’s as much use as a chocolate teapot
Just wish there was a few specs regarding runtimes and lumens!!
Interested
Might it come with a magnet on the base? That would increase its utility. (Sorry if someone else has asked this Q already)
Yes
definitely interested
interested !
Lumens go from ~0.3 at the low end to … um, direct drive at the high end. It has four emitters and a FET and a 21700 cell, so it should be able to pretty much max out four of whatever emitter it’s using. So, for 219B that’s probably a maximum of 2000-2400 lm. For XP-L HI it probably goes up to ~4500 lm or maybe even higher.
Of course, it won’t stay at that level for long… too much heat.
