Battery extraction?
9 posts / 0 new
Pete7874
Pete7874's picture
Last seen: 19 min 48 sec ago
Battery extraction?
What’s the easiest way to extract a leaker AAA cell stuck inside the flashlight? Superglue something that I can use as a pull handle? Drill?
Thanks!
nottawhackjob
Last seen: 1 week 6 days ago
Drill it about 3/4’s of the way through. A series of holes if the single center one doesn’t cut it. Then take a flat blade screw driver that’s bigger than the hole and start wiggling/prying it around to loosen/separate the battery metal sides from the tube wall. What also helps is an electrical contact spray that has lubricant. CRC 2-26 spray can for about $3 should be in every modder’s tool bag. Available at Home Depot in the Electrical Department. Great stuff. And it doesn’t stink.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
toddcshoe
toddcshoe's picture
Last seen: 9 hours 33 min ago
I used a self tapping screw. Screwed it right into the top of the battery and used some pliers to pull it out. Worked once. Not sure if it would work in your case.
"Everywhere I go, there I am"
atbglenn
atbglenn's picture
Last seen: 6 months 3 weeks ago
I’ve done it more than once using drywall screws.
Boycott Nike
chinooker
chinooker's picture
Last seen: 5 min 57 sec ago
then the cleanup
atbglenn
atbglenn's picture
chinooker wrote:
then the cleanup
Yeah, that part sucks if there’s a lot of corrosion.
Boycott Nike
nottawhackjob
If the sides are really jammed up/expanded against the tube walls it’s gonna be a bitch without prying around like I said above. If it’s mildly jammed up a screw in the center and pliers might work. The main problem is the metal sides of the batt if they’re essentially corrosion welded to the tube. The center stuff is relatively soft and pliable.
AlexGT
AlexGT's picture
Last seen: 2 days 14 hours ago
Tie it to a strong string and go to a safe place and spin it as fast as you can, centrifugal force should eject the battery, if your get tired or frustrated just let go of the string and go home and order another one…
Problem solved!
Pete7874
Pete7874's picture
Got it out. Thanks guys!
