ENEDED
Okay, so an emitter swap was easy. I took a pipe wrench around the flat sides to grip the light and then water pump pliers to loosen the bezel. I did use 3mm rubber strips in between to avoid scratches and to grip the light. The bezel is glued it came loose easily. It’s 20mm mcpcb and it’s centered by the reflector only.
I swapped in a XHP35 HI 5000K D4 from Mountain Electronics. The beam is excellent…
Interested :-)
Intrested depending on price.
I’m interested in the MR30.
Just ordered the MR30 via your link. Thank you for helping me once again to spend my money, Freeme! :smiley:
Price?
Hi, could i have the coupon please.
Thank you.
Hi , can I have the code please?
Thanks
definitely interessted!
Interested depending on price.
Interested.
Flashlight arrived today. Thanks for a good price.
Hope you like it!
Mine arrived, too….can’t wait to tear apart the black pastic bag. :smiley:
I received mine last week. It is an excellent light and very bright. The UI is nice. Finish and build quality is excellent. I compared it to my Nitecore EDC23 and the Rofis is slightly brighter with a more concentrated hotspot/beam.
Interested for the right price. Please send me the code. Thanks!
Interested. Please send code. Thank you.
Interested, please send the code. Thanks!
Please PM me code.
Thanks!
Comparison of ROFIS MR30 vs Sofirn SP32A. The torches are similar in size and performance, ROFIS is a bit wider.
