[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
Interested
Great Advice regarding choice etc…
For me both inline and angled Flashlights have a place due to work and activity requirements……. So hopefully this may replace the Nitecore HC30 I have but that will depend on quite a few things once I have played with one…. Could be it’s as much use as a chocolate teapot :smiley:
Just wish there was a few specs regarding runtimes and lumens!!
Interested
Might it come with a magnet on the base? That would increase its utility. (Sorry if someone else has asked this Q already)
Yes
definitely interested
interested !
Lumens go from ~0.3 at the low end to … um, direct drive at the high end. It has four emitters and a FET and a 21700 cell, so it should be able to pretty much max out four of whatever emitter it’s using. So, for 219B that’s probably a maximum of 2000-2400 lm. For XP-L HI it probably goes up to ~4500 lm or maybe even higher.
Of course, it won’t stay at that level for long… too much heat.
Interested
Thank you for that Toykeeper…. Now I have a slight corner dribble!! :open_mouth:
have interest…
Wow I’m very excited for this. It’s like a Emisar D4 angle light.
I’m curious, if I put a 40T or 30T in there, will it push too much current for the 219B? How many amps does it take to be harmful to the 219B?
I wouldn’t recommend running it on turbo for long. The 219B emitters have higher Vf than 219C, so they won’t allow as much current to pass… but they also can’t stand anywhere near as much current. So I’m not really sure what to expect.
It might be a good idea to artificially lower the FET power on the 219B version, but it’ll require some testing to figure out if that’s necessary… and I’m not really set up for that kind of testing.
With most direct-drive lights, the emitters and batteries are chosen so the battery’s voltage sag and the emitter’s Vf curve will intersect at a safe point. But when using stronger cells or weaker emitters or lower-Vf emitters, things get tricky.
Are xpl hi and 219B the only emitters available?
I don’t really know what emitters will be used.
However, the ones I’ve seen are 219B and SST20.
Product listed.
Nice, and lots of emitter options, including SST20 10W NW 4000K CRI95. Definitely going to try that.
http://www.ff-light.com/index.php?route=product/product&product_id=54
Freeme, please update my interest to two lights, thanks!
The new details looks great. I thought I had posted interested before.
2 please… YES THATS TWO PLEASE
Prolly mentioned, gonna have battery available for purchase?
