Low Output Cheap Flashlight recomendation.
7 posts / 0 new
Pregulla
Pregulla's picture
Hi All,
I am looking for a flashlight for astronomy to convert to red either by swapping the LED for cheap red one or by using transparent red tape. From what I have remembered a 1$ “Police 3w Light” would fit the bill (cheap, dim and will run forever on dead AA), but to my surprise the two specimens I have ordered were much brighter than expected (guesstimated at about 20lm).
Is there something similar, but with output closer to 1-5lm? A not too expensive light (sub $10) that has a low-low mode and starts on it or has memory would work too (AA, AAA or 18650). If there is something that comes with red LED and is dim enough it would work too, but what I have seen seemed to be too bright.
Thanks.
Frumious
Last seen: 4 months 4 weeks ago
Astronomy. Great viewing of Mars this month. I recommend and use the Coast FL70 headlamp from Costco. (Costco item#1087612) Comes in a two-pack for under $30. Runs on 3AAA batteries (6 included!). It has dual red LEDs that are not overly bright. These are in addition to its white/focusable LED. The two nicest features for you: 1) The red LEDs are controlled by a separate switch from the bright white one – you won’t be temporarily blinded and lose you night vision, 2) Hands free operation.
jch10400
I go on night hikes at a local preserve that requires a red flashlight. Since I had a couple of AA Maglights sitting around unused, I ordered a kit online that had clear, red, and blue lenses along with a lanyard. I think it was $4. Problem solved.
Pregulla
Pregulla's picture
I already have a “conversion kit”, now I need something to convert Wink
I am not from US, so no Costco for me. I’ll have to stick with the usual suspects – eBay, AliExpress, and alike.
P.S. Couldn’t make any detail on Mars yet. I guess I need higher power and better seeing. The Jupiter was impressive though.
ZozzV6
ZozzV6's picture
Last seen: 4 hours 40 min ago
I think the Sofirn SP10B or SP10A will suit this. It has a very very low moon mode and it can either start in moon (short press) or in last used level (long press) or turbo (double click)
Pregulla
Pregulla's picture
Yeah, it looks like what I am looking for. Thanks.
ZozzV6
ZozzV6's picture
And what I also like in it that it has a 4 click lockout. I don’t like long press lockouts. It can long pressed in a bag when something fall on a light .
