Hello my dear friends!
Thanks to my partner Steven from banggood.com i got some deals renewed some of you asked for...
find the links and codes in M4D M4X deals
some of them are Oldies, but Goldies ;)
Thanks I bought 2 TO46R to swap in the triple SST-20 mcpcb from Kaidomain.
Astrolux FT01 and Mateminco TK01 the same?
Yes. It’s possible the Mateminco version includes the strike bezel and the Astrolux version does not. Please verify this before buying.
HKEQUIPMENT.net has opened some warehouses in USA, United Kingdom, Australia and Germany to be nearer to their customers.
making receiving the orders much more confident :)
REMEMBER! you get -8% on everything in the FLASHLIGHTS Category(<- use this link) with the code: M4DM4X (or HKE80)
i also got some deals:
Coupon MD7ywnb2 makes US$ 79,16
warehouse: Hong Kong, USA, United Kingdom, Australia, Germany
Coupon MD7ywnb2 makes US$ 87,96
from .HK warehouse:
Coupon MDUC307 makes US$ 52,95
Coupon MD8sh3h makes US$ 56,91
Coupon MD8sh3h makes US$ 59,46
Good to hear they’ve come to Australia. Be nice if they brought some batteries too, USD$15surcharge per unit atm.
I see the GT Mini for $32. Seems like a good deal. Do you think it’ll go any lower on black friday?
thats called "China lotto" ;)
:money_mouth_face: Ha Ha….
Or US Stock Market in last 2 days……
Is 2.5A correct? Surely you would need higher amps to get 2100 lumen?
On a single xml2 2.5A will only get you 750 lumen, maybe.
Edit: I will find out and let you know.
@JasonWW, they are literally copy pasting the BLF GT manual everywhere with that 2.5A turbo of a buck driver, not a FET driver.
That’s what I was thinking. I asked TA if he knew what a more realistic amp draw would be, since he seems to be the only person who has actually used one.
Lexel tested an S42 with a 30Q it drew 10A!
Wasn’t that 9,95A number with the stock driver?
Efficiency on the light was abysmal because of the springs having high resistance for a quad 219C setup, resulting in non-negligible power losses and the spring getting hot(that was on my spring BTW, my experience), along with the FET’s specs being subpar for the purpose.
Yes, stock driver. It was one channel FET. It drew 10A, but output seemed a bit low.
The TA based driver is only in the S43 and is a 2 channel FET + 1 design.
Hopefully TA will answer back about it’s amp draw. He told me previously that the output is still around low 2000’s range. It can definitely be improved with spring bypasses.
Besides the Mateminco version being available in copper, it looks like it also gets a different 18650 battery tube with the finger grooves in it.
Lexels S42 review.
Okay, Texas_Ace says about 10A is what can be expected with your typical high drain cell like a 30Q.
If you bypass the springs you might see 15A.
Hey!
available again for members: (M4D M4X DEALS)
and you maybe see those posted elsewhere - always compare my prices ;) ...
Item | Code | Coupon price | better member deal? |
Folomov Portable USB Charging | 59f946 | $10.59 | NO |
West Lake Tactical 20mm Rail | 0f3a80 | $24.95 | NO |
Astrolux MF02 XHP35 HI | 8aadd0 | $79.95 | NO |
BW-ET1 | 51517a | $9,60 | NO |
Astrolux S43 | 9f1297 | $29 | YES |
NITECORE TM10K | 6ab60b | $200 | YES!! |
GT mini | eb4fa7 | $39,99 | YES |
ADEASKA SQ4 | ADASQ4 | $33,69 | YES |
Xiaomi MiJia 1080 | cebd24 | $66.66 | NO |
MINI TS80 | 15b0a6 | $66.66 | NO |
My Amutorch X9 3*SST40 came in today - Thanks Martin and Neal
FOLLOW THIS LINK TO NEALSGADGETS.COM
-> ask me for the code to save $$$ before oprdering!
check my youtiube channel for some videos... https://www.youtube.com/user/sepp4646/
Holy cow how did you convince them? Are they going to release a NW version of the R90C too?
