[Optisolis/E17A/E21A] Jetbeam Jet-µ
292 posts / 0 new
clemence
clemence's picture
Last seen: 1 hour 51 min ago
Nichia E17A/E21A: 2000K - 6500K (R9080)/Red/Green/Blue/Amber
83% (50 votes)
Nichia Optisolis 2700K - 6500K (R95+ CRI)
17% (10 votes)
Total votes: 60
Edited by: clemence on 12/14/2018 - 12:07
clemence
clemence's picture
Hi All,
I’m planning to bring a simple AAA twisty with very high CRI. I’m getting into AAA EDC these days. They are very practical and a true EDC because it’s so small. My Fenix E05 saved me countless times even deep in the woods.
The plan was already proposed to the manufacturer with only few things remain.
The FL will have these features:
- Fenix E05 form factor
- 4 modes: 0,5lm – 20lm – 100lm – slow beacon at 100lm (approximate OTF using D240 E21A R9080. Less with Optisolis)
- Mode memory
- AAA only, no 10440 support
- IPX 7
- Pocket clip
- mod friendly
- interchangeable TIR lens
The question is in the poll. Two different MCPCB required, that’s why I asked.
With E17A or E21A you can get whatever beam profile you like depending the optics. Longer regulated runtime
With Optisolis only micro lens TIR optics will work, expect 30° + FWHM. Shorter regulated runtime due to its higher voltage
Or…. is it better to provide both MCPCB? I know you guys won’t let anything sits unmodified for too long…
UPDATE181213: First run with E17/E21 and 757 copper MCPCB (+ Optisolis TIR optic test)
http://budgetlightforum.com/comment/1427677#comment-1427677
UPDATE181214: First runtime test and beamshots
http://budgetlightforum.com/comment/1428333#comment-1428333
UPDATE181215: Uncooled Jetusolis runtime test
http://budgetlightforum.com/comment/1428587#comment-1428587
UPDATE181216: JetuE21A runtime test (before – after optic modification)
http://budgetlightforum.com/comment/1429036#comment-1429036
UPDATE181217: Final runtime test result of both Jetusolis and JetuE21A prototypes
http://budgetlightforum.com/comment/1429406#comment-1429406
UPDATE181218: Some pictures of the the modifications, beamshots, and measurements
http://budgetlightforum.com/comment/1429910#comment-1429910
- Clemence
djozz
djozz's picture
Last seen: 2 hours 41 min ago
I voted for E17A/21A because it allows for a narrower spot, which I like more and in general seems more versatile to me. What you notice of the CRI difference between E21A R9080 and the Optisolis is only marginal and may appeal only to extreme snobs.
Having been involved in the development of a small AAA light myself, I’m looking forward to the design Smile
clemence
clemence's picture
djozz wrote:
I voted for E17A/21A because it allows for a narrower spot, which I like more and in general is more versatile. What you notice of the CRI difference between E21A R9080 an the Optisolis is marginal and may appeal only to extreme snobs.
Me too, Optisolis seems to work best for general lighting not flashlight enabled yet. I’m not going to make this FL completely from scratch, that would requires a huge committed funding which I don’t want to do ATM. I’m going a custom order route just like my previous Armytek built.
- Clemence
Pavlo
Last seen: 2 hours 25 min ago
E21a Smile
twisted raven
Last seen: 41 sec ago
Voted E21A
Gunga
Gunga's picture
Last seen: 1 day 4 hours ago
Voted E21. For a different option.
Noctiluco
Noctiluco's picture
Last seen: 4 days 6 hours ago
Yes, I prefer too a narrow beam, better with a diffused lens; the old Fenix E05 27 lumens has a perfect beam of light, narrow with smooth transition
jon_slider
jon_slider's picture
Last seen: 20 hours 14 min ago
clemence wrote:
- Fenix E05 form factor - 4 modes: 0,5lm – 20lm – 100lm – slow beacon at 100lm (approximate OTF using D240 E21A R9080. Less with Optisolis) - Mode memory - Pocket clip
great options!
I like mode memory, it makes for a very versatile EDC.. set to moon for nightstand duty, set for medium for daytime..
I hope the pocket clip works on a hat (bezel up option), that is a Very useful feature for hands free, although even without a clip, I sometimes just put a light under my hat, no clip required..
ToyKeeper
ToyKeeper's picture
Last seen: 40 min 5 sec ago
Considering how little energy is in a AAA cell, is there any chance of getting a lower medium mode?
Usually my most-used level on any light is about 5 to 10 lm, so on something like this I’d probably do the modes a little differently if possible. Like maybe 0.2 lm, 8 lm, 36 lm, 100 lm. Not sure if that can be done here, but I think it would be nice that way.
DavidEF
DavidEF's picture
Last seen: 23 min 37 sec ago
What does this mean? “Red/Green/Blue/Amber” It isn’t explained in the first or second posts.
- The YKK Philosophy
Schoki
Schoki's picture
Last seen: 3 weeks 2 days ago
I’m for a E21A as well, but the driver would probably be changed to a single-mode one by me
clemence
clemence's picture
I was about to ask helps from any of you driver programmers there. And your name came to my to-ask list. This one should be easy to reprogram. The plan also includes an optional dongle for reprogramming (much later). This is still beyond my expertise ATM but I’m more than willing to learn. It uses PIC MCU instead of AVR.
clemence
clemence's picture
MCPCB for E21A can work with E17A as well. And this broadens the choice to not only warm or cool white only, but also Red-Green-Blue-Amber E17A. E17A shares the same voltage characteristic with E21A, including their single color variants. Nichia use phosphors converted colored LED. Same forward voltage for all E17A and E21A family.
- Clemence
DavidEF
DavidEF's picture
Phosphor converted single wavelength colors? What’s the advantage of that, besides having the same Vf across the board? I’d think that would be an inefficient way to produce those colors.
chadvone
chadvone's picture
Last seen: 1 month 3 days ago
I voted E17A/21A If its a lower powered aaa I want throw. And I don’t even know what they are. I am just going off djozz post.
ToyKeeper
ToyKeeper's picture
I’ve never actually attempted to use a PIC MCU. Tterev3 published some example code for the PIC10F322 though.
For now, the next MCUs I’m looking at are AVR models with more than 8 pins. But after I get the hardware abstraction layer written for those, maybe it’d also be feasible to add back ends for PIC models.
staticx57
Last seen: 3 hours 9 min ago
clemence wrote:
Hi All,
- Clemence
This obviously.
Phlogiston
Last seen: 1 week 3 days ago
I voted for the E21A because I have tunnel vision, so a tight beam is normally more useful to me. What’s the tightest optic for this LED? 5° or 10° would be nice Smile
What will “slow beacon” correspond to? I like 0.5Hz to 1Hz, at 50% duty cycle. Tunnel vision again – it’s very easy for me to miss short, infrequent flashes. A brief flash once every 5 seconds – call it 0.2Hz at 5% duty cycle – would be useless to me, for example.
adam7027
Last seen: 1 hour 23 min ago
While I would be very happy to see an 5000K Optisolis and a 3500K Optisolis variant, beam versatility as a selling point made me chose E21A/E17A. I’d settle for a fine beaded optics with 15-20° beam diameter.
Phosphor converted color LEDs are also seem to be a good feature for E17A in my understanding.
For white LEDs, I’d choose 3000 or 3500K CCT for warm white option, and 4500K CCT for neutral white.
I think, output levels would be best like this: 0.5 lm – 4 lm – 25 lm – 100 lm.
I don’t know your possibilities, but if you could arrange a single AA EDC as well, I think, that would be also very good. (Single AA could be a better match with a single E21A emitter in term of max. recommended power level)
Gunga
Gunga's picture
I would buy AA too.
marcus_z
Last seen: 2 days 13 hours ago
nothing to add here, AA as EDC is just perfect
clemence
clemence's picture
Anyone with PIC programming experience here? With reprogramming kit, we can adjust whatever modes we want. The limit is only max current (230 – 250mA). I wanted to bump a bit more to 350mA but that would be unpractical with small capacity AAA NiMh and could easily fry the E17A with 10440. It can take 10440 for under a minute in max before gets very hot (both the driver and the LED), hence no recommendation.
- Clemence
clemence
clemence's picture
That’s it E17A/E21A wins! Thanks for all the feedback =)
- Clemence
Bob_McBob
Last seen: 2 hours 56 min ago
Thumbs Up
SKV89
Last seen: 4 hours 21 min ago
I voted E21A. I’m not a big fan of twisties and AAA lights. I already have a bunch including Skylumen E01vn with 3200k 90CRI yuji emitter. I like clickies and AA. But since it is from Clemence, I will be buying it regardless.
3000k E21A would be my ideal for AAA sized lights Wink
Lightbringer
Lightbringer's picture
Last seen: 54 min 10 sec ago
Goggle “yellow gap”. Monochromatic LEDs can be pretty efficient in red, green, especially blue, but yellow/amber is pretty dismal efficiency.
PCA LEDs take a shorter-wavelength blue (sometimes violet?) LED and convert that to yellow/amber more efficiently than a regular monochromatic y/a LED.
I always wondered but never really found out definitively the spectral spread of PCA LEDs. Monochromatic might be a nice narrow spectrum if that’s what you need, but PCA for a wider spread (eg, everything from orange to yellow-green but a peak/dominant wavelength in the yellow/amber range).
ToyKeeper
ToyKeeper's picture
I’ve only tried some Cree color LEDs, like XP-E2 and XQ-E… but they make nice vivid colors. The quad XQ-E RAGB setup I made for my lightsaber gives me a pretty vivid spectrum for everything except purple. I didn’t get red enough red emitters or blue enough blue emitters to make a good purple.
DavidEF
DavidEF's picture
So, you need deep blue and far red, but you got “regular” blue and red? But other than that, it’s working fairly well? Do you have the firmware finished yet (or close to finished)? I can’t remember if you’ve mentioned it.
ToyKeeper
ToyKeeper's picture
Sorry, this was kind of a tangent which barely relates to the thread topic. Was mostly just saying that the color emitters work pretty well, though some shades need relatively specific components — like photo red and royal blue instead of regular red and blue.
About the saber project, I haven’t done much with it lately. I need to make a new PCB, but before that I need to learn how. And the code needs to be rearranged to enable a higher frame rate, because 60fps looks weird on a fast-moving object. Could also really stand to be ported to tiny841 in order to get the 4th PWM channel working better. But I’ve been busy with other projects instead.
I’m not really sure why color emitters were relevant for this thread, except that the MCPCB may be compatible with some color emitters. But color isn’t really the point of the AAA EDC project.
clemence
clemence's picture
Color emitters is not relevant to most of us but it is an additional option since color E17A can use the same footprint as E21A. Especially when the beacon 4th mode can be added as planned. Green beacon is very eye catching from afar.
Last night I tested the stock board and at only 230mA the OEM non DTP board perform OK, with very minimal temp sag. This is a good thing for cost reduction but could be a deal breaker for those who plan to put 10440 in it.
- Clemence
