@X3
Do they have the same lens size? Would be interesting to see the same emitter in both lights to see the difference between the lights itself.
Can someone give me the exact head diameter? Want to order a dust cap from KD (or comes the Cometa with cap like the Z1).
I should have bought a second one for this price. With the new powerfull UV leds it would have been fun to build a UV thrower.
Just tested with 365nm UV, the lens let it pass
Also, just measured the head : 53mm in diameter.
I tried a sliced SST20 in my Cometa, the beam is less tight than with the larger headed B158B
Two packages arrived today. The first was filled with two Shockli 26650 nicely protected and with extra heatshrink wrap (ordered directly from Shockli on Aliexpress).
Second one was the Cometa. Who the hell did the assembly? And have they ever heard of Quality Controll? I do not think that i ever bought a light with so badly assembled parts.
The scratched tread on the head is not nice but i can live with it. The head sounds like a rattlesnake, the led is reflowed crooket, switch tailcap with to much preload, Negative wire on driver was shorting against the pill + spring soldert out of center (next shorting point if the spring moves only a bit more to the side.
Its a nice host but i think it is really irresponsible to sell these light to people with no modding experience.
Wedged two small pieces, roughly 1”x1”, of 20lb paper. No more free wheeling head.
My cometa got marked as shipped today.
Paid 9/24, marked as shipped 9/25, then within a few hours reverted to back order, shipped 10/10
Hopefully it actually ships.
TheOnlyDocc nearly quoted my reaction word for word when I got the first couple GB lights, you have definitely gotten one of the worst.
Nice to hear that i am the lucky one :sunglasses:
I shorten the silikone nob inside the rubber boot. Grinded all edges i can find smooth (all brass edges are sharp enough to cut isolation or your skin), reflowed the led, changed ledwires to 20AWG, and put some silikone grease on the thread (the scratched one that holds the lens). Reassambled the light and now its working fine.
Tomorrow i will try to make some beamshots of the Cometa and the 1504 side by side. Both with fet driver and XPL Hi led.
Seeing both lights on the shelf got me thinking about the SBT-70. 12Amps generate a lot of heat. And the 1504 is a lot bigger. Also the much bigger lens would give me possibly a tighter beam.
If the SBT-70 goes into the 1504 the Cometa will get a Seoul Viosys Z5
Taking care of the XPL Hi (and also reflowed 219Cs on 10mm sinkpads for another mod).
Finally! A solid zoomie!
On mine, the MCPCB retaining disc is made of a plastic, not Al (?).
A plastic mcpcb retainer disc…?
Or are you referring to this plastic piece in this picture.
Could you post a pic. Please ?
No, not that one. It's on the front of the light, over the LED.
No kidding, that is a first for sure, and definitely safer from how they soldered the leads,
Thanks, that is really odd and really it’s a first that I’ve heard of, I wonder when and how or why they ever went to all that effort on these Cometa’s
Thanks
Could you take a pic for us?
I had already put kapton tape over the leads and then plinked it on the desk for that Al ding but no... Plastic! My only concern is that it melts... almost prefer the Al since I know to insulate the leads.
Sorry. I have problems posting picks with imgur. It looks just like the Al one, black. But I gotta snooze! I'll see if I can do it tomorrow.
Mine is plastic tto.
I was wondering why anyone would feel the need to put kapton on the solders, then saw that the original one was in anodized Al…
Wise choice, both for safety and cost.
So i guess they did fix it then, Well that’s good to know i probably got older stock.
I got an aluminium retaining disc.
LED and wires are soldered nicely too.
I'll trade you disks!
Yes, the soldering is good!
Sorry, i will keep the alu disc. It’s a nicely made part. (the brass pill is nice too btw)
I will put a thin plastic washer around the LED though, because it looks as if it is not really pushing down the LED PCB on the pill.
I was wondering the same that the alu disc might not have press on MCPCB firm enough.
Are you sure it is not pressing on MCPCB enough? Hope you can share your investigation here.
