I have a LiitoKala Lii-500 too …but then i found this : SKYRC MC3000 , OK only 4bay but you can set nearly all parameters , charge - discharge and the values are displayed on the Charger - per Cable on your PC - or over Bluetooth on your Phone . For me one off the best ……
I paid $15 for my Lii-500 without power supply vs close to $100 for the Skyrc MC3000. I’m sure the MC3000 is alot better. But for the price, you can’t beat the Lii-500.
I think there are a few floating around but more should be posted over the coming weeks as people get their lights.
The top of the ramp on this light is around 50-60, after that you have to go to turbo mode which is 100. There is no regulation on these modes since it uses an FET for the high modes.
The normal GT has the 80% high mode and a regulated buck driver. Although the voltage overhead is not enough to allow full regulation in the high modes except with fairly full batteries (which is why we ditched the buck driver for this light that pulls about 4x as much power, there would of been no regulation anyways).
I have the 4-bay version of the Griffalcon charger from Mtn above, and I don’t really like it. Sure, it’s pretty, and when it works, it works, but the thing isn’t “set and forget” reliable. For example, when putting more fully-charged cells in, it will often read them as 4.2v and not charge them, and you have to disconnect and reconnect the cell multiple times to get them to read correctly. (verified actual voltage with my fluke) I really wish my nitecore i4 had a higher charging current.
+1 I have the same problem with my All-88 eight bay charger. Sometimes it takes several reconnects for it to get off of the 4.2v reading. Very irritating, but other than that, I really like the charger. Not the best charger for top offs. I also purchased mine from Richard. Wonder if it might be a batch thing or if they all act this way. I have so many chargers, I haven’t really looked into it. I mainly use it now to charge AA NiMH batts for my speedlites.
OK this is an argument …. but i spend so much money for my lamps ( 2 GT`s , 3 Conversion Kits and a little bit more ) so i decided 70€ on BG is OK …… YOLO
The only update I have gotten since the holiday is they are working hard to get caught up on all the group buy orders this week. Generally I hear more so they must really be working hard on it.
The GT that is the Buck design? This is the GT70 thread so I wanted to clarify.
Your best bet is to ask ToyKeeper. She is the one that has the repository and created it (iirc).
I know Anduril can usually be flashed to the FET style drivers running NarsilM, but I don’t know about a buck driver.
It seems likely it could be made to work with the GT70, but it being 12v would require some custom coding. Same for 6v versions. I don’t think she has a 6v or 12v version right now.
I just got an update last night actually. Forgot to post it this morning.
They have most of the remaining GT70 and conversion kit orders packed but they need some time to sort out all the orders, they are worried about making mistakes on the shipping so they hope to get them shipped next week.
I would prefer this then them rush out the door and possibly have problems so I was not that upset about the delay.
I have something from China shipped on Friday, delivering Monday. Don’t know what it is as it weighs more than the carriers I ordered and less than the GT70. I assume the weight is an estimate. Description is “sample of flashlight” like the first light, but who knows? I have absolutely no problem waiting to make sure the orders are correct, but would not mind waiting even longer if it meant we could get proper shipping / tracking info prior to delivery.
