Sofirn C8F host. 21700 C8F Available
Regarding the climb, I wonder if the stock FET has a high turn on voltage. This would explain the low output. Then the high channel resistance would cause the FET to get hot, and I believe this causes the channel resistance to go down which would increase the output.
Hey guys, sorry that C8F 21700 version has this issue. I was told it’s caused by MOS component. I don’t know what MOS is but I would love to send new driver to whose C8F max output lower than 3000 Lumens via 21700 battery.
Please PM me.
This is what we were suspecting. The MOSFET or FET for short.
The big black component labeled 2D030L. I’m going to try out my hot air station and see if I can swap it out for a better one.
Sofirn, thanks for your excellent customer support as always! PM sent!
I just contact Cissy of Sofirn and she told me to send a new driver :+1: Never disappoint with Sofirn service and fast respond ,looking forward for new Sofirn light :blush:
same here thank you sofirn!
Hi Sofirn
I want to purchase a C8F 21700 from Aliexpress but am now concerned about this defective driver issue.
Can you advise if their stock is being checked/replaced/fixed ?
Thanks
Wow! What great customer service.
I’m happy with swapping the fet myself, but I appreciate sofrin looking to address the issue nonetheless. That’s awesome, as usual from them.
Another point worth noting is that I’m really happy with the ramping on this light. It’s much smoother and a good speed. Compared to the sp32a v1, I feel this light has much improved ramping.
It’s pretty close to the d4. Not quite narsil, but very close imho.
It’s getting more and more rare for companies to listen to customer feedback. Sofirn seems to be doing it right.
So what can we do about this giant retaining ring? Think i can grind it down at an angle on the inside edge to fit a driver with 7135 on the bottom?
Also mind the other side of the driver: the edge on which the driver rests is wide too and may touch driver traces and components.
I have a 20mm lexel driver so it might be ok on that side but this is a good point. Overly complicated driver shelf and Alu ring. Almost better to use 17mm and spacer
Sure.
Any suggestions for a 17mm constant current driver that works with an E-switch? I’m really interested in this host…
Use fet+1x7135 driver with no parts on spring side.
In such a nice host it’s a shame to not have more regulated output options.
20mm like this? FET + 7135 Driver - 20mm - MTN-20DDm
Mtn also has a 22mm board but then you would have to sand it I guess…
contactcr
Yes.
+1
Just a quick check. Does anybody know if it’s safe buying from AE official store at this point or is it likely I will still receive a light with a dodgy FET? Many thanks.
Ask them before ordering just in case.
Perhaps they will just strip the lights of the faulty driver and replace it, or they’ll just sell them as hosts.
