No unexpected issues. Got a plastic retaining disc, I’m pretty sure it’s acetal though, nicely machined, so no concerns there (shouldn’t soften below 180°C). Solder joints and thermal interfaces will be reworked for good measure. 26AWG wiring is a bit thin, so that goes out too.
Lots of material in the pill, it could easily hold a 20mm driver if necessary. 22-23mm maximum.
PS: If you have the pill disassembled anyway, deburr the inside as well. Mine had quite large burrs on the sidewall (where the end mill stopped for the 2 wiring holes) that could potentially come loose and short something out.
Where’s the rule not to behave like some communist?
Seriously though, what about “crap” then ?
It’s the same thing / substance.
often used in the same context: “piece of crap”
or “that scared the crap out of me”
or “crappy battery” for example.
Another thing, Raccoon guy.
Since you’re so occupied with rules and behaviour of people on BLF,
What the hell are those knife murderer pictures supposed to mean?
You apparently glorify serial killers?
You know this is supposed to be a “family value forum”, don’t you?
Also suited for children (who use words like sh(it) and crap by the way…)
You could have avoided this risqué conversation by the way.
As for being occupied with rules and behaviour, simply pointing out the forum rules if they are not being followed, like raccoon did, sounds like normal behaviour to me.
To be clear, flagging my post as rude because i quoted “sh(it)” is not normal behaviour.
If you want to police on a forum, become a moderator and chase everyone you don’t like out.
By the way, why do you have a political signature when you’re always against discussing politics (which is not allowed on BLF, and for good reason)?
……aaaand that’s all for me for today in this topic…
Before you go, would you please remove the posts that you filled with language that is considered rude, this is supposed to be a family-friendly forum and even apart from the rules for me that is part of why I like it here.
Yes, there was a problem with the driver pocket also. The major I.D. of the driver shelf was oversize, say 19-19.5mm I think? The pass thru hole was like 17.8-18mm so you could actually move the 17mm driver over enough to short out on one of the SMD’s or positive lead… something like that…
Also since the mcpcb board isn’t screwed or glued, (the Z1 mcpcb was screwed down) a couple members had the board rotate when they tightened the cover on, and sheared the leads. IIRC….
First I would like to thank T18 for posting this deal :+1:
I bought the light with the Vap battery,
it was delivered in a bit less then 3 weeks
my light was also dropping out of turbo to moon after 10 seconds or less
but after reading I found that it was the temp setting
I turned the temp / heat setting off and it is working fine now
I also opened the light and the solder looked fine
but I insulated the blobs anyways as a precaution
I like the light so much that I went back tonight to buy another
but the price is now 47.99 :person_facepalming:
hope they lower it again,
I would definitely pick up another
