Yes. It’s possible the Mateminco version includes the strike bezel and the Astrolux version does not. Please verify this before buying.
Hello my dear friends!
HKEQUIPMENT.net has opened some warehouses in USA, United Kingdom, Australia and Germany to be nearer to their customers.
making receiving the orders much more confident :)
REMEMBER! you get -8% on everything in the FLASHLIGHTS Category(<- use this link) with the code: M4DM4X (or HKE80)
i also got some deals:
FENIX TK25 CREE XP-G2 S3 LED 1000LM 18650 TACTICAL FLASHLIGHT
works on: TK25 Red , TK25 R&B, TK25UV
Coupon MD7ywnb2 makes US$ 79,16
warehouse: Hong Kong, USA, United Kingdom, Australia, Germany
FENIX TK25 IR INFRARED + WHITE XP-G2 TACTICAL LED FLASHLIGHT
Coupon MD7ywnb2 makes US$ 87,96
from .HK warehouse:
FENIX UC30 2017 CREE XP-L HI V3 1000LM USB RECHARGEABLE
Coupon MDUC307 makes US$ 52,95
FENIX HP40F FISHING CREE XP-G2 R5 WHITE BLUE LED HEADLIGHT+USB POWER OUT
Coupon MD8sh3h makes US$ 56,91
FENIX BT20 CREE XM-L T6 NW NEUTRAL WHITE MTB BIKE HEADLIGHT HELMET MOUNT
Coupon MD8sh3h makes US$ 59,46
Good to hear they’ve come to Australia. Be nice if they brought some batteries too, USD$15surcharge per unit atm.
I see the GT Mini for $32. Seems like a good deal. Do you think it’ll go any lower on black friday?
thats called "China lotto" ;)
:money_mouth_face: Ha Ha….
Or US Stock Market in last 2 days……
Is 2.5A correct? Surely you would need higher amps to get 2100 lumen?
On a single xml2 2.5A will only get you 750 lumen, maybe.
Edit: I will find out and let you know.
@JasonWW, they are literally copy pasting the BLF GT manual everywhere with that 2.5A turbo of a buck driver, not a FET driver.
That’s what I was thinking. I asked TA if he knew what a more realistic amp draw would be, since he seems to be the only person who has actually used one.
Lexel tested an S42 with a 30Q it drew 10A!
Wasn’t that 9,95A number with the stock driver?
Efficiency on the light was abysmal because of the springs having high resistance for a quad 219C setup, resulting in non-negligible power losses and the spring getting hot(that was on my spring BTW, my experience), along with the FET’s specs being subpar for the purpose.
Yes, stock driver. It was one channel FET. It drew 10A, but output seemed a bit low.
The TA based driver is only in the S43 and is a 2 channel FET + 1 design.
Hopefully TA will answer back about it’s amp draw. He told me previously that the output is still around low 2000’s range. It can definitely be improved with spring bypasses.
Besides the Mateminco version being available in copper, it looks like it also gets a different 18650 battery tube with the finger grooves in it.
Lexels S42 review.
Okay, Texas_Ace says about 10A is what can be expected with your typical high drain cell like a 30Q.
If you bypass the springs you might see 15A.
Hey!
available again for members: (M4D M4X DEALS)
LUMINTOP IYP365 Titanium
Nichia 219BT/XP-G2(R5) 200LM 3Modes Portable EDC LED Pen Light Flashlight
IMALENT DX80
8x XHP70.2 32000LM Super-Bright Outdooor Searching LED Flashlight 806M
and you maybe see those posted elsewhere - always compare my prices ;) ...
Item | Code | Coupon price | better member deal? |
Folomov Portable USB Charging | 59f946 | $10.59 | NO |
West Lake Tactical 20mm Rail | 0f3a80 | $24.95 | NO |
Astrolux MF02 XHP35 HI | 8aadd0 | $79.95 | NO |
BW-ET1 | 51517a | $9,60 | NO |
Astrolux S43 | 9f1297 | $29 | YES |
NITECORE TM10K | 6ab60b | $200 | YES!! |
GT mini | eb4fa7 | $39,99 | YES |
ADEASKA SQ4 | ADASQ4 | $33,69 | YES |
Xiaomi MiJia 1080 | cebd24 | $66.66 | NO |
MINI TS80 | 15b0a6 | $66.66 | NO |
My Amutorch X9 3*SST40 came in today - Thanks Martin and Neal
IMALENT MS12 is available to preorder in NW!!
FOLLOW THIS LINK TO NEALSGADGETS.COM
-> ask me for the code to save $$$ before oprdering!
check my youtiube channel for some videos... https://www.youtube.com/user/sepp4646/
Holy cow how did you convince them? Are they going to release a NW version of the R90C too?
new deals: Fitorch P25 and Haikelite MT03 (new driver by TA)
today i received deals for two very interesting flashlights:
Members can find the deals here: M4D M4X deals
non members can contact me
Fitorch P25
4x XPG3 LEDs with 3000LM
5 Modes IPX-8 Waterproof LED Flashlight
INCLUDED USB chargeable 26350 Li-ion Battery
(the links get you to the shop for more pictures and information)
Features:
- 3,000 Lumens maximum output with 4 XPG3 LEDs.
- 4 illumination levels (High, Medium, Low, & Ultra Low), Strobe, & SOS functions.
- Powered by a 26350 2,000mAh Lithium-ion Micro USB port rechargeable battery.
- High-strength aerospace aluminum body.
- Mil-Spec hard anodized for extreme durability.
- 10° optical lens for high light transmittance.
- Power detection and location beacon function.
- Waterproof in accordance to IPX8
- Inpact resistant to 2meters.
Package included:
1 x Fitorch P25 LED Flashlight
1 x 26350 battery
1 x USB Cable
1 x Lanyard
1 x O-Ring
1 x Holster
HaikeLite MT03 TA Devourer
XHP70.2 P2 21000LM
CW/NW High Power LED Flashlight
Specification:
Product name: | HaikeLite MT03 TA Devourer XHP70.2 P2 21000LM CW/NW LED Flashlight |
Brand: | HaikeLite |
Model: | MT03 (New Driver) |
Emitter Type: | XHP70.2 |
Emitter BIN: | Cool white,Neutral white |
Material: | Aluminum Alloy body with HAIII Anodize black surface Finish |
Battery Configurations: | 4x High Drain >10A button top 18650 |
Switch Type: | Side electrical switch with big Transparent rubber boot |
Switch Location: | body side of the flashlight |
Max Output: | 21000 Lumens |
Lens: | Ultra Clear Double-sided AR coated Glass lens (99% Light transmision ) |
Reflector: | Aluminium OP Reflector |
Waterproof: | IPX8 Waterproof |
Color: | Black,White(limited edition) |
Weight: | 620 Gram |
Size: | 130mm length x 72mm Head x 50mm body |
Nice. The price on your site for haikelite MT03 TA is a bit off
