Smallest 18350 light?
57 posts / 0 new
sac02
sac02's picture
Last seen: 22 hours 41 min ago
Any new players in this segment since last year?
Gebe
Last seen: 17 hours 7 min ago
I recently purchased a Armytek Partner C1 V2 that was on sale for $17.00, (though shipping was $10.00), that takes both 16340 AND 18350 cells. It’s just under 3” long and a tad over 3/4” wide. It’s a neat little light.
jon_slider
jon_slider's picture
Last seen: 1 hour 58 min ago
congrats, steal of a price
When I compare size I also like to focus on Weight
Armytek Partner C1 specified weight empty is 57 grams
there is also a Niteye Eye 10, spec 48 grams w clip
left to right
Ti S Mini 29 grams wout clip, 32 grams w clip, PT16 does not weigh 40 grams, it actually weighs 52 grams, or 57 grams with the new pocket clip, RRT-01 actual weight is 48 grams empty, w clip
The PT-16 is 2.75” tall and 1 1/8 wide, so shorter, lighter (w out clip), but fatter, than the Armytek
The Sunwayman T16R is the same weight as the Ti S Mini, and almost as short, but fatter.
Lightbringer
Lightbringer's picture
Last seen: 5 min 23 sec ago
Wuben E345 and such?
Nice 2-stage twisty.
sac02
sac02's picture
Wuben website says 16340 and no mention of 18350 compatibility. Diameter of 21mm makes me think it’s unlikely it will accept 18350.
Gebe
55 grams. Big Smile
freefly
Last seen: 3 weeks 23 hours ago
Certainly not new, but I didn’t see it on the list yet:
NiteEye Eye10.
Not the smallest @ 80mm x 24mm, but it’s a cool little rotary that will take 18350s. Beer
Lightbringer
Dough! Yeah, 16340 only, just like the Jet-II. Was thinking for some reason it took an 18350, too.
I know I got something that takes an 18350, but Hell if I can recall what.
jon_slider
freefly][quote=sac02 wrote:
… NiteEye Eye10.
I agree. Eye10 is the same as the RRT-01 except there are 11 detents on the Eye10 ring. I like detents, they allow repeatable light levels, the infinite RRT-01, can never be set to the same level twice. And the Eye 10 is still available, the RRT-01 is no longer for sale new.
nquinn
Last seen: 1 week 2 days ago
Anyone know the lightest headlamp / right-angle 18350 or 14500 light?
Oddly it’s hard to find a body lighter than the h03 at 44g, and that’s for an 18650!
Would like to bring overall weight down though and use a 14500 or 18350 instead as the battery.
toddcshoe
toddcshoe's picture
Last seen: 2 hours 50 min ago
I don’t know about the weight but last time I was on the Illumn site they had the Thrunite TH20 on sale for $25. It takes a 14500 I believe.
"Everywhere I go, there I am"
jon_slider
if you add the 45gm for an 18650, that H03 comes to 89 grams
the 18350 Armytek Tiara (48gm), plus an 18350 (21gm), totals 69 grams..
Highly recommended: Armytek modded to High CRI from Clemence
Here is a post about the quad E21A mod
and a pic of some of Clemences Quad E21A 2000k, being tested in a light of mine (not a Tiara)
chinooker
chinooker's picture
Last seen: 1 hour 8 min ago
not exactly “B“LF, eh?
sbslider
sbslider's picture
Last seen: 24 min 25 sec ago
I like my TH20, but from what I have read it is not very light compared to other headlights. Don’t have any specific data for comparison, I am sure Thrunite has the weight listed on their website.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Agro
Agro's picture
Last seen: 2 min 6 sec ago
Maybe this ?
toddcshoe
toddcshoe's picture
Ran across this. Andrew and Amanda have the Nitecore EC11 on sale for $39.00 right now. Don’t know for how long.
Enderman
Enderman's picture
Last seen: 20 hours 17 min ago
I’m sure someone could easily make a flashlight as small as the lux-rc minion.
All it takes is a small cylinder with the LEDs on the driver PCB and a piece of glass.
No optics or anything, just a mule.
Using flat LEDs like XP-L HIs or black flats could reduce the height even further.
Agro
Agro's picture
But for some reason nobody does it. Sad
Kindle
Kindle's picture
Last seen: 1 day 16 hours ago
jon_slider wrote:
left to right
If only they made a version of the S Mini sized for 18350. Le sigh.
derfyled
derfyled's picture
Last seen: 1 hour 59 min ago
Enderman wrote:
I’m sure someone could easily make a flashlight as small as the lux-rc minion. All it takes is a small cylinder with the LEDs on the driver PCB and a piece of glass. No optics or anything, just a mule. Using flat LEDs like XP-L HIs or black flats could reduce the height even further.
A nice challenge for CRX !
CRX
CRX's picture
Last seen: 6 min 12 sec ago
Big Smile Smallest 18350 light I’ve made was the copper & aluminium triple with FET driver & tail clicky.
Length – 60 mm
Width – 25 mm
Weight – 97 grams (with cell)
Max – 1400lm
jon_slider
10/11/2018
1/6/2019
update, I disagree with my former self
I tried an Eye10 and the detents are inconsistent and not spaced to my liking
it has given me a new appreciation for my RRT-01 smooth ramping dial… maybe I should try some hi cap IMR 18350… hmm
I think one of these protected button tops might be good.. the flat top version does not work in the RRT-01
pic is a link to review
HKJ wrote:
Keeppower 18350 1200mAh P1835C2 (Black) 2017
Can anyone confirm if these fit the RRT-01? (not too long?)
they are for sale here:
https://www.illumn.com/18350-keeppower-p1835c2-1200mah-protected-button-...
CRX
CRX's picture
Probably too long. I made a custom flat top protected for my 01, very tight fit.
I had to grind the tail pin down and alter the RvPo ring to make it fit.
I could be wrong though, would be best if you could measure somehow with the cells you have and thin spacers?
jon_slider
CRX wrote:
Probably too long.
darn
Protected Keepower, length: 39 mm
Protected Fenix 16340, length: 34 mm
maybe I need to go to the store and try the cell out in my RRT-01 before I buy it..
CRX
CRX's picture
That would be good. Screw gently though, maybe with the o-ring off Wink
Jerommel
Jerommel's picture
MascaratumB wrote:
Some 16340s are longer than the 18350, though! I received a Wuben 16340, protected, that is longer than the Aspire 18350 unprotected.
It is not larger,though!
CR123A is taller than 16340 too.
A 16340 with USB charging PCB is the same length as a CR123A.
Often 16340 lights are also meant to take CR123A, or vice versa.
2Q19
